SOURCE: AT&T 974 corded phone
if your dsl is on the same line it will mess up micros for intercome system. Move dsl to another line
SOURCE: I am having a problem, I to would like to forward
In order for a Partner to forward to an outside cell, the processor needs to be an R6 or higher.
Is yours? If you press Feature 59 from a display phone, it will tell you what release it is.
If feature 59 doesnt display anything, it is way older, and will not work.
SOURCE: Intercom / page problem with AT&T phones model 944 and 955
I have the same setup in a small office I consult for and I found the intercom problem to be caused by the DSL filters. It seems the DSL filters also filter out the frequency that the phones use to communicate with each other. If any of the phones had a DSL filter on them the intercom and hold button would not work properly with the other phones in the system without filters. Once I took the filters off the intercom and Hold function worked fine.
SOURCE: "due to surconstances beyond our
depending on what number you are dialing, if you live in an area where you can still dial 7 digits to reach your party, you should realize that your telephone provider sometimes changes calling zones without your knowledge, so what previously worked as a seven digit number, may require and area code plus the number, eg: 954-922xxxx or if the number you're dialing is out of your area code, you may have to dial, 1-972-922xxxx.
The last thought that comes to mind is that the number your dialing may be to an area that is having facilty troubles and the call can't go through until the problem is fixed.
SOURCE: Had a bad electrical storm.
The damage is not to the phone line it is to the phones. Unfortunately this is very common with powered phones as they are almost never kept on surge protectors and are very fragile. You will need to purchase a new base station to use with existing phones.
