Posted on Jul 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I changed a toner cartridge and now it is not alligned and I don't know how to allign it. I have an HP CP2025 and I have tried doing the cleaning and printing the test pages. I don't know what to do now.
Anonymous
Level 2:
  • Expert 304 Answers
  • Posted on Jul 10, 2011
Anonymous
Expert
Level 2:
Answers
304
Questions
0
Helped
202368
Points
741
Calibrate the product
Calibration is a product function that optimizes print quality. If you experience any print-quality problems, calibrate the product.
1. Open HP ToolboxFX.(in your PC)
2. Click the Device Settings folder, and then click the Print Quality page.
3. In the area for Color Calibration, select the Calibrate Now check box.
4. Click Apply to calibrate the product immediately.
1helpful
2answers
Hp clj 2025 cleaning
I had the same problem and it was the pick-up roller that was at fault. You can buy a new one for less than 20GBP or do what I did. Take the old one out and reverse the rubber. There are plenty of online tutorials on how to change the pick-up roller - the first one you remove. It's a two minute job. Reversing the rubber is easy. Just prize the inner clip out of the roller and put the rubber back on with the shiny side out. It worked first time and no more print errors. HP CP2025 How to Replace the Pick up Rollers and Separation Pad
Changed toner---back side now prints dirty with band on the top. Did the cleaning procedure - no luck
If you changed toner because old was empty and now you have this defect with the new cartrige, it is most likley a defective cartridge. Try the old cartridge again, if it prints clean, then you know for sure it is the cartridge. If you purchased a new HP cartridge, get it replaced by HP, they warranty their toners against defects. If you bought a 3rd party toner, return it to where you bought it and get them to replace it. If you had your old toner refilled by someone, get your money back, they don't know what they are doing. This type of defect is often caused by a filled waste toner bin then then runs back out when you print. Some refillers just throw toner in and don't empty the waste toner bin.
2helpful
I bought an HP 6110 printer and had to put a #57 ink cartridge in.Now it's saying that my paper is too narrow.I have 8.5" by 11" paper in and all my settings are for that.And it won't print if I...
Hi
after changing cartridges printer needs to alligned printheads
and this can hapen only with A4 paper
just put one page A4 in your printer until allignment is done
if i help you pls vote me
2helpful
4answers
How do i install a toner chip on my hp Cp2025
TONER CHIP on CP2025 printer:
This resource may help
http://resources.lasertekservices.com/hp-smart-chips-overriding-this-lockout-mechanism-with-reset-chips/
Gives types of chips to use, sales in USA, and certain things to take note of.
The toner reset chip replaces the original HP ID chip and is designed to be used only on refilled HP cartridges.
It is not recommended to force toner cartridges to run on empty, as this can cause damage to both the printer and the toner cartridge.
The reset chips are dedicated to one color only, so that user can not swap toners.
As for actual physical installation, just push the new ID chip in until it clicks into place. The correctly manufactured ones should be a snug fit.
I have seen techs using a drop of contact glue behind the chip-board to secure it.
Copper pads face outwards towards matching printer pins.
See photo for polarity 'square' pad.
My printer is Samsung, not HP, so your toner cartridge may be a different shape.
My printer will not pass an allignment
  1. Open the printer and remove and reinstall the same cartridges again (important)
  2. Ensure paper is loaded and the paper slider is correctly positioned against the edge of the paper
  3. When asked to allign, do so again
Hope this helps!
nLinked
Computer Support Services
1helpful
I changed the black ink cartridge as per instructions and the printer printed an alignment paper which i then placed in the printer for alignment but the alignment failed
the page should be absolutely new.and the scanner glass should be absolutely cleaned.and 1 main thing u replaced your black cartridge.but if your colour cartridge is empty it will not accept the allignment complete thing.it will show allignment failed as the particular colour is missing in your allignment sheet which is required to get the allignment complete.
2answers
k24674
ADMIN Andrew
ADMIN Andrew
