Apple MacBook Mac Notebook Logo
Anonymous Posted on Aug 26, 2008
Repair Error Code -36
"…A error has occurred while reading the disc. Possibly the disc is damaged or dirty."
I tried using brand new DVD's, but still no good. Sometimes it happens after about 5 minute, and other times 30 seconds.
On rare occasions the movie will continue playing after the error code appearance.
How can I repair this error?
  • Anonymous Sep 08, 2008
    On my MacBook I also keep Getting error -36, this is very annoying!
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1935
Points
Apple Technical Support Number 1-833-493-0111
Level 2:
Habit-Forming:
Scholar:
  • Apple Expert 36 Answers
  • Posted on Nov 25, 2017
Apple Expert
Level 2:
Habit-Forming:
Scholar:
Answers
36
Questions
0
Helped
9376
Points
239
How Mac Error Code 36 Occur?
While copying the files from your Mac system you may spot error with code 36 stopping your Mac OS X finder process. Actually, the error code represents "The Finder can't complete the operation because some data in FileName can't read or written. To Fix Mac Error Code 36, just read the easy steps are given below.
Steps to Fix Mac Error Code 36:
Step 1: The first thing you need to do is launch the terminal and to launch this you need to follow the path Applications/Utilities/ or with Spotlight.
Step 2: At commandprompt you need to type "dot_clean /Path/To/Directory/With/Problem/" and if you need any help, call to Mac technical support.
Step 3: When dot_clean is finished, now try the file copy again and possibly fix error code 36 Mac OS X without facing any other issue.
Step 4: The error code may appear on any Mac computer device except the symptoms that may differ due to configuration of the computer.
Step 5: If the problem persists especially while copying the file from a Mac network share through external drive some sort, or to and from a windows computer.
Step6: Delete all .DS_Store files on a Mac using the command line that works temporary workaround if for some reason dot_clean fails.
1 833 493 0111 How to Fix Mac Error Code 36 on Mac OS
Anonymous
Level 2:
Novelist:
Champion:
  • Expert 382 Answers
  • Posted on Sep 01, 2008
Anonymous
Expert
Level 2:
Novelist:
Champion:
Answers
382
Questions
0
Helped
159755
Points
449
-36 is an I/O error. Your drive or laser may need to be recalibrated. Possibly replaced. Is this the internal drive or an external. Is this unit under warranty?
My Magnavox DVD reads disc error
QUICK ANSWER
A disc error may be due to having the wrong type of DVD in the player, having a dirty disc in the player or the disc having scratches or cracks. When it comes to the type of disc, it must be compatible with the DVD player for it to work.
FULL ANSWER
When this error occurs, pull the disc out of the player and look at the underside for smudges and fingerprints. If these are present, using a soft cloth to gently remove them generally solves the problem. Cracks and scratches generally require replacing the disc because they prevent it from working.
or try this link..if a popup comes up on the link just close it down.
Step by Step Guide to DVD CD or Game Disc Repair The DIY Video Editor
Hitachi BX37E error
You can try to clean the laser lens first with a q-tip and 99% alcohol. If that fails, you should take it in for repair because the laser lens mechanism may be out of line because of a bump. There may also be a dust build up inside that prevents the proper movement of the lens. This can be done at home too.
tip
When you try to play a DVD game on Xbox 360 it tries to play as a movie?
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Ps3 error 8001002B with headset pairing
The code means "dirty or damaged disc". The PS3 has encountered some kind of problem reading the disc. Possibly the laser could be having problems, possibly the disc. Try another game disc. If it works, the game disc you are trying to start is somehow damaged. If it doesn't, the laser most likely has a problem.
Ps3 slim error code 8001002b what could this code be.
If the laser is the problem you can try and clean it with a DVD laser lens cleaner like this one :
http://www.walmart.com/ip/Innovera-CD-DVD-Laser-Lens-Cleaner/14915544
Regards
Hi this is peter i have a problem hat i nt figer out. trying to install Punch Home and Land Premium i get this-- Error 1305.Error reading From file C: Program Files\Punch! Home and Land Premium\ tool...
Hello peter4927,
An, "Error 1305" message mean that; your computer is unable to read the "Program Disc" properly.
This error can occur if your CD or DVD is damaged, dirty, or caused by dust.
This can happen, if another program is "preventing your computer from reading the "Program!"
You will also receive this error if the "Disc Drive" is damaged or dirty.
Try cleaning the "Disc" first!
"Use a Disc Cleaner, to clean the CD-ROM / DVD Drive.
Place the "Program Disc in the Disk Drive; then "Restart the Computer!"
This will have the CD, or DVD start-up {Automatically}.
Next, you can try to start the "Disc" by using the "Auto-Run."
To do so; place the 'Disc' in the "Disc Drive Tray."
Next, [right click] on the "Computer Icon" to open the 'computer window'.
Now, right click, on the Disc Drive, and select the either, "Open, Explore or {Auto-run}.
Hopefully it will start.
Repeat each action if necessary!
"If there is anything else, you may need help with?
Write a 'comment,' I'll be here to assist you!"
"Best Regards"
2answers
Won't recognize the disc as a game... how do we fix this? Its a brand new Wii game.
Check the bottom of the Game Disc (the side without any labels or writing) for any dirt or damage (such as cracks, scratches, etc.).
If the games look significantly damaged, such as with scratches or cracks, it will need to be replaced.
If the game looks dirty (fingerprints, smudges), try cleaning the Game Discs. If the problem persists, the Game Discs will need to be replaced. or Click here to download repair guide
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
1helpful
2answers
Toshiba Recovery Disc Creator isn't working
hello lazerr_man,
Try to use another freeware burnprogram like burnatonce to create an
other CD, just to check if the Combo-drive is writing properly.
If you don't get any error messages like the ones from Toshiba program, then the problem is the toshiba software.
If other burn programs find difficulties in accessing CDs or DVD-Rs
then the drive itself giving you a hard time and might seek for replacement.
You may find the toshiba exchange parts too expensive and the internal drive is still reading disks properly, then think about an external dvd-rw drive, but make sure to buy a highspeed USB one (or even firewire, if the laptop has the port), else it will run rather slowly.
good luck
Hi, my ps3 wont read bluray discs. I was getting an 800 series error code on the disc startup but now it won't even see the discs. It does see ps1 and ps2 discs, as well as cd's and dvd's. I ordered an...
Hello sir
Here The 800 Series Error Codes :
80029945 - Can’t playback burn BDr movie (error in picture above)
80029946 - Attempting to play burnt Dual layer NTSC disc on a Pal ps3
(workarouns is to transfer files to ps3 via TVersity)
(added 24th Sept 2007)
80029301 - An error occurred during the delete operation (attempting to delete
some ps2 homebrew from virtual mem card) (added 15sept2007)
80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3
processes - have to sign in to use them) (added 04-sept-2007)
80710A06 - An error occurred during the install operation (error when downloading
game from PSN - network error occured (added 30thAug2007)
8003041F - An error occurred during the copy operation (using media server) (added
27aug2007)
80010006 - An error occurred during the start operation (added 22aug07 - corrupted
folding install)
80010007 - An error occurred during the start operation (added 17aug07 - during
disc swap tests)
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
