Lakewood HV 18-c Floor / Box Fan Logo
Posted on Jul 10, 2011
Our Lakewood HV21T fan started making a screeching sound. We assume it needs cleaning and lubricating but we are not sure where. We have removed the front grill and the entire blade/shaft assembly from the back of the fan. And now we have no idea what to do next.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1586
Points
Hi Kjorex, do you still have this fan?
-Josh
Do you bypass the run capacitator on a lakewood model hv-18 fan with a 2.4 motor
More than likely it's not the start capacitor why your fan will not run this more than likely it's not the start capacitor why your fan will not run this lubrication try turning the fan motor by hand if it does not turn freely it's lubrication I have answered this another post.
more than likely it is lubrication spray WD-40 into the oil holes after you have unplugged the fan of course Keep turning the fan and you'll notice will start turning more freely apply more oil to the rear of the motor as this is an oil bushing you're putting more oil into
hope this solves your problem
Troubleshooting lakewood fan model hv 18
This one the best brands on the market that I have ever owned.
If the fan motor will not turn on or hums and/or turns slowly more than likely its a lubrication problem.
1. Unplug the fan from the wall remove the 516 screws to the cage
2. Try turning the fan blade by hand if it is tough to turn more than likely it's a lubrication problem
3. You will have two oil holes one in the front one in the back spray WD-40 into these holes, turn the fan blade if it starts to free it up apply more WD-40 and keep turning the blade add more WD-40 until the blade turns freely. Especially in the rear oil hole because this is an oiled bushing that you are adding oil to. Once the fan is turning freely replace the front cage with all the screws plug the fan and I hope this solves your problem. You may add 3 in 1 oil or some other very light lubricating oil periodically.
I hope this solves your problem Mike
My vaio VGC-LS25E starting sounding like an idling farm tractor on a cold morning, ie, very loud. Now it's making a very loud screeching sound. I assume this is the fan, but want to make sure if that's...
Have you been using any high end programs (like PhotoShop, or some video editing software) lately?
If not, your case is most likely full of dust. Get a can of air, and clean it out.
Also make sure all of the vents are open.
Hope that helps,
Forest
Fan does not blow. Believe we need a new fan motor.
Have you considered checking to see if the fan motor might just need cleaning and lubricating?
Most small fans and heaters, have small fan motors, in which the bearings have dried out over the years. If you have made an electrical check on the motor leads-- and you have electric going into the windings, likely the motor feels warm? (If not-- possibly a bad splice where the supply wire attaches to the tiny armature wires?-- check , and check continuity)
If you want to tear into the fan motor, and clean up and lubricate the bearings-- here are some tips:
First you need to get inside the heater of the fan housing-- by removing the protective covers.
Note the screws, sizes, locations, and how the protective covers will go back on when you are ready to reassembly-- Mark where the screw holes are that line up with the matching other parts.
Then remove the motor from it's bracket (Possibly have to remove the fan first?)
You will have to remove the fan, to lubricate both front and real bearings.
Next you will need to remove the 4 long screws that hold the motor frame together-- Be sure to mark the original alignment, so you can reassembly correctly.
Now, with the fan removed, gently separate the Front and rear half's of the motor. Usually the windings will stay with the portion of the motor wher the wires are still attached. Either way, you are going to have to get the bearings to slide off both Shafts of the armature-- without breaking the delicate winding wires-- the wires are hair thin on small motors!
Now clean up the caked on residue on the shaft where the bearings ride, with rubbing alcohol. Clean up the internals of the bearings as best you can- making sure the pores of the oil-lite bearings are not plugged with solids. Now begin the gentle process of getting the bearing wicking to soak up new oil. When you are sure the reservoirs are well saturated, then generously lubricate the shafts, and slip them thru the bearings again-- retracing all your steps above, The motor shaft should turn freely now. You can test the motor without the fan on-- to be sure you have the motor itself reassembled properly.
Double check all the splices, switches, and any high temperature limit switches for continuity-- and trace the wiring all the way back out thru the power supply cord.
What did you find, and what do you need to do next?
Let us know--
Mack B
4helpful
Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
7helpful
2answers
Does the lakewood fan have a fuse that can be replaced?
No, it is either the speed control, capacitor or motor. You can get parts, if it worth your time, try nelsonappliance.com and part # LW007JRMOTOR
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Loud screeching sound coming from the unit
It sounds like the fan motor needs lubricating. Do you need help with this?
Top Lakewood Dryers Experts
Jay Finke
Jay Finke
goneforever.
ADMIN Eric
ADMIN Eric
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
