The drain is clogged.It has to be cleaned to make it drain.
Jenn-Air grease trap is easy to disassemble and easy to use.
So you can clean it manually and make it drain:---
Click this link below and follow the procedure:---
http://howtobyme.blogspot.com/2011/07/how-to-clean-clogged-grease-drain-on.html
This should help.Thanks.Helpmech.
The linked solution does not apply to ranges, just to cook tops. The drain bottle is at the bottom of the range, behind the bottom access plate which can be removed by lifting then pulling (not under the countertop as stated in the linked solution). If the pipe is clogged, I recommend a long flexible wire brush. This one worked great for me:
http://www.amazon.com/Platypus-08831-Pla...
It's not sold for stove cleaning but it's perfect for the task.
