I newly installed my all toners but now when ever I print anything I just get cyn and yellow print and can't print text in black what could be the problem?
The problem is cyan and yellow toner are low, u will change the cyan and yellow it will be cleared otherwise the will be empty u can't print any thing suppose one will empty other cartridge will not work
First, make sure that the toner cartridges have enough toner. The toners may be exhausted. In case the toners are ok, the printer requires servicing/ cleaning of lenses and mirrors inside the printer. Please refer here to my earlier solution to this problem, which was very helpful for the users of Color LaserJet 2600n Printer.
GoodLuck! Dont forget to appreciate the solutions if I could have been of any help! CreativeTECH
change the cartridges. Theres nothing else that can alter the color like that without rewriting the drivers. B4 you do, take each one out, shake gently from side to side to even out any toner, and try again.If they print better, your toner is low.
If you have BLACK Marks on the paper the YELLOW roller does not need to be cleaned usually.
To clean the yellow toner off the roller use a DRY lint free cloth. For this issue my suggestion for a resolution to the Yellow toner issue is replace the toner. They are not supposed to leak in the first place.
As for the BLACK tone on the left of the page you most likely have a Fuser issue causing that.
chnge the magenta toner scaner ok ........after that is working but ...do not any idea about this just call me :+91-09328015664
and Email:[email protected]
Generally this is a toner cartridge issue. Are you using genuine toner cartridges or generic remanufactured? I have attended alot of repairs on this model when clients use generic cartridges. Usually a genuine cartridge fixes the problem.
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies.
Change from stop at out, to override at out.
It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
