I have a hoover 500M which we moved to a new place for my daughter. It continues filling until it overflows. I tried turning the power off while it was filling and the water stopped flowing as soon as the power was turned off but when filling even on the low load keeps filling. The spin and drain etc are working normally.
Re: I have a hoover 500M which we moved to a new place...
There is a sensor that detects the water level in the tub...it is usually a pressure switch that has a vacuum tube coming off it going to the level switch..it may be defective or even more simply, the vacuum hose may have come off
To replace your Hoover washing machine water inlet valves watch this instructional video http://youtu.be/78D5ieegS98
Or follow the instructions below
Turn of the power at the power point and disconect cord. Turn of water supply to the machine. Disconnect the water hoses Unscrew the screws on the rear cover and remove Use a screwdriver to press in the inlet valves plastic locking clip Pull the inlet valves upwards and disconnect spring clip electrical terminals Push in new inlet valves and connect spring clip electrical terminals Reinstall plastic locking clips Reinstall rear cover and reinstall screws Reinstall water hoses and turn water on Reconnect power cord and switch power on
There is a fill switch that is not being triggered. Find out where that is. The dog hair could be the culprit. This switch is but cutting the tank fill. God Bless John
Probably very repairable but impossible to say how much without looking inside and fiddling around and checking a few things.
Fault could be caused by several possible faults at widely varying cost.
I suggest you call a friendly local white appliance engineer...
it just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
