Briel Breil Milano Chronograph BW0491 Watch for Men Logo
Posted on Jul 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The long second/split time hand resets to 58secs and not 00secs
Ansel Alberto
Level 2:
  • Expert 248 Answers
  • Posted on Jul 10, 2011
Ansel Alberto
Expert
Level 2:
Answers
248
Questions
0
Helped
148578
Points
473
You have to set the long second by pulling the crown to it's third position(which you can set the time) then push the upper button until you reach 00 then push again to normal position. that's it. i hope i had helped you...
Luminox navy seal watch skipping second hand by 5 seconds still keeping perfect time, changed battery after testing (shows 1.5 v) still skipping. what could be wrong
a mechanical part needs replacing, unless your have some form of funky split time running? replacing the battery should have reset it though.
tip
Watch glossary: S.
SAPPHLEX CRYSTAL
Seiko's trademarked name for a fusion of sapphire and mineral glass crystals
SCALE
Graduation on a measuring instrument, showing the divisions of a whole of values, especially on a dial, bezel. The scales mostly used in horology are related to the following measuring devices: tachometer (indicating the average speed), telemeter (indicating the distance of a simultaneously luminous and acoustic source, e.g. a cannon-shot or a thunder and related lightning), pulsometer (to calculate the total number of heartbeats per minute by counting only a certain quantity of them). For all of these scales, measuring starts at the beginning of the event concerned and stops at its end; the reading refers directly to the chronograph second hand, without requiring further calculations.
SCREW BALANCE
Before the invention of the perfectly weighted balance by use of a smooth ring, balances were fitted with weighted screws to get the exact impetus desired. Today a screw balance is a subtle sign of quality in a movement due to its costly construction.
SCREW-DOWN LOCKING CROWN
A crown which aids water resistance by sealing the crown against the case. The seal is achieved by the matching of a threaded pipe on the case with the crown's internal threads and gasketing while twisting the crown to lock it into place.
SECOND TIME-ZONE INDICATOR
An additional dial that can be set to the time in another time zone. It lets the wearer keep track of local time and the time in another country simultaneously. See also GMT and world time.
SECTOR, see rotor.
SELF-WINDING, see automatic.
SHOCKPROOF or SHOCK-RESISTANT
Watches provided with shock-absorber systems (e.g. Incabloc) help prevent damage from shocks to the balance pivots. Thanks to a retaining spring system, it assures an elastic play of both jewels, thus absorbing the movements of the balance-staff pivots when the watch receives strong shocks. The return to the previous position is due to the return effect of the spring. If such a system is lacking, the shock forces exert an impact on the balance-staff pivots, often causing bending or even breakage.
SIDEREAL TIME
The conventional time standard refers to the sidereal year (defined in terms of an average of 365.25636 days) considered to be perfectly regular until very recently, but - even though this is not true - the difference is so slight that it is virtually neglected. As a unit of time, the sidereal day is used mainly by astronomers to define the interval between two upper transits of the vernal point in the plane of the meridian.
SKELETON, SKELETONIZED
Watches whose bridges and pillar-plates are cut out in a decorative manner, thus revealing all the parts of the movement.
SLIDE
Part of a mechanism moving with friction on a slide-bar or guide.
SMALL SECOND
Time display in which the second hand is placed in a small subdial.
SNAILING
Decoration with a spiral pattern, mainly used on the barrel wheel or on big-sized full wheels.
SOLAR POWERED
A watch that uses solar energy (from any light source) to power the quartz movement. Citizen call their solar powered watches "Eco-Drive".
SOLAR TIME
The time standard referred to the relative motion of the Earth and the Sun governing the length of day and night. The true solar day is the period measured after the Sun appears again in the same position from our point of observation. Due to the non-uniform rotation of the Earth around the Sun, this measure is not regular. As an invariable measure unit, the mean solar day corresponds to the average duration of all the days of the year.
SOLSTICE
The time when the sun is farthest from the equator, i.e. on June 21st (Summer solstice) and December 21st (Winter solstice).
SONNERIE (EN PASSANT)
Function consisting of an acoustic sound, obtained by a striking work made up of two hammers striking gongs (s.) at set hours, quarter- and half-hours. Some devices can emit a chime (with three or even four hammers and gongs). By a slide or an additional pusher it is possible to exclude the sonnerie device and to select a so-called grande sonnerie.
SPLIT-SECOND CHRONOGRAPH
Chronographs with split-second mechanisms are particularly useful for timing simultaneous phenomena which begin at the same time, but end at different times, such as sporting events in which several competitors are taking part. In chronographs of this type, an additional hand is superimposed on the chronograph hand. Pressure on the pusher starts both hands, which remain superimposed as long as the split-second mechanism is not blocked. This is achieved when the split-second hand is stopped while the chronograph hand continues to move. After recording, the same pusher is pressed a second time, releasing the split-second hand, which instantly joins the still-moving chronograph hand, synchronizing with it, and is thus ready for another recording. Pressure on the return pusher brings the hands back to zero simultaneously, provided the split-second hand is not blocked. Pressure on the split pusher releases the split-second hand, which instantly joins the chronograph hand if the split-second hand happens to be blocked.
STAFF or STEM, see arbor.
STOPWATCH
A watch with a seconds hand that measures intervals of time. When a stopwatch is incorporated into a standard watch, both the stopwatch function and the timepiece are referred to as a chronograph.
STOPWORK
Traditional device (now obsolete) provided with a finger piece fixed to the barrel arbor and a small wheel in the shape of a Maltese cross mounted on the barrel cover, limiting the extent to which the barrel can be wound.
STRIKING WORK, see sonnerie and repeater.
SUBDIAL, see also zone.
A small dial on a watch face used for any of several purposes, such as keeping track of elapsed minutes or hours on a chronograph or indicating the date.
SUPER-LUMINOVA, see luminescent.
SWEEP SECOND HAND
A center second hand, i.e. a second hand mounted on the center of the main dial.
on Jan 11, 2010 • Watches
1helpful
On my new Victoronox 24332, the sweep hand for the stop watch does not reset to zero but rather to about 17 seconds past '12' O'clock. The split second hand also stops just past Zero on...
Follow the instructions on the following link. I believe it works on all or most Swiss quartz chronographs. Worked like a charm for my Mondaine and my Zodiac. Hope it works for you too.
http://mondainewatch.co.uk/my-chronometer-doesnt-go-to-zero.html
4helpful
Chronograph hands reset to wrong places
go to the citizen web site (citizen.com) and select "technical support" and then "setting instructions".
Enter the number off the back of your watch snd the click on "get setting instructions"
The instructions include the steps you need to take to zero the hands.
9helpful
2answers
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 • Watches
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
14helpful
Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
48helpful
6answers
Seiko chronograph alarm
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
13helpful
3answers
How to Set Alarm
This is the movement used in the following Seiko watches..
SNAC74 SNAC75 SNA548 SNA694 SNAC40
SNAC41 SNAC42 SNA749 SNAC03 SNA411
SNA414 SNA765 SNAA03 SNAA05 SNAA01
SNAA02 SNAA61 SNAB61 SNAB62 SNAB64
SNAB65 SNAC25 SNAC29 SNAC35 SNAC36
SNAA61 SNAC38 SNA283 SNA695 SNAA30
HOW TO SET ALARM TIME
1. Pull the crown out to the second click position.
2. Press button “B” to set the alarm hour and minute hands to
current time.
3. Push the crown back to normal position.
4. Pull the crown to the first click position.
5. Press button “B” to set the alarm hour and minute hands to
desired alarm time.
6. Push the crown back to normal position.
Note:
Alarm setting on a 12-hour basis only. Alarm will ring at the
designated time for 20 seconds; one time alarm only. The alarm
needs to be reset in order to re-engage the alarm function.
HOW TO USE CHRONOGRAPH
1. Set crown at normal position.
2. Press button “A” to Start/Stop/Restart.
3. Press button “B” to Split/Split release/Reset.
HOW TO USE ALARM DIAL
AS DUAL TIME DISPLAY
2. Pres the button “B” to set the hour and minute hands to time of
a different time zone.
Top Briel Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Briel Watch Expert? Answer questions, earn points and help others
