Sony BRAVIA  KDL-46V3000 Television Logo
Anonymous Posted on Jul 10, 2011
There is light at the screen but no picture and sound normal
Marlowe Amoguis
Level 2:
Sergeant:
  • Expert 405 Answers
  • Posted on Jul 10, 2011
Marlowe Amoguis
Expert
Level 2:
Sergeant:
Answers
405
Questions
0
Helped
105824
Points
988
HI.usually when problems occurs without picture, either slanted picture has vertical or horizontal light on it.The one responsible for this is what we called ..PICTURE-TUBE.It is a cathode -ray tube in the television receiver that translates the received signal into a picture on a luminescent screen.It is the picture tube who creates an image that is composed of identical horizontal lines.So any problems in regards to picture whether it only shows vertical or horizontal.its the PICTURE TUBE that was damaged.Hope this idea helps..Thank you for choosing fixya.
  • Anonymous Jul 10, 2011
    LCD TV does not have any picture tube, what is your next idea about problem?
My LED LG TV 32 inch is not diplaying pictures on screen but the sound is working normally. how can I fix it?
hi you may have a power supply,or the led or leds in the panel are shorted,thanks
shaun
2answers
1helpful
Tv has no picture but has sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
How to fix my lcd tv and magic remote?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
1helpful
My Magnavox TV give sound but no picture. When I turn it on the light in the bottom right hand screen goes green, then flashes to yellow and goes back to green. The screen does not change it is constantly...
You need to replace your backlight inverter.
Check that all voltages are coming from the power supply as they should. The power supply will be stamped with the correct amounts, and you just read with the multimeter to confirm.
After those check out ok, you will need to replace the inverter to "light" your screen again.
You can hear sound because the tv is ON, but the inverter isn't lighting the screen!
Hope this helps, please rate!
I have no picture, but no red lights
It's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
This is a serious issue that will need the attention of a skilled Microsoft tech. Contact Microsoft asap.
No picture on flat screen new, with cable
IF THIS IS A LCD---TURN ON, AS NORMAL AND HAVE A SIGNAL INPUT,,CABLE ,SATELLITE CONNECTED TO THE ANTENNA INPUT .MAKE SURE YOU HEAR SOUND.. HOLD A LIGHT (THE BRIGHTER THE BETTER) IN FRONT OF THE THE SCREEN ('BOUT 3 INCHES)--IF YOU SEE A DIM PICTURE---BAD SCREEN AND THATS BIG BUCKS---IF STILL NO PICTURE--CIRCUIT BOARDS AND USUALLY THATS BIG BUCKS!! GOOD LUCK
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
