Hi I have plugged the red blue and green in my HD tv ad understand that I need to put audio in (red and white) but I have no more holes in my telly!! I have tried putting them in the scart but no joy, I have got one hole that is audio but it is a different size, what am I doing wrong, the tv is only 6mths old thank you
Red ring is not the only problem with Microsoft Xbox 360. This amazing
device also has some more common problems like Audio but no video
problem, disc read error etc. Microsoft is providing extended warranty
only for red ring problem. Means you will have to spend some money to
get this problem repaired also if you plan to send your xbox to
Microsoft, you will have to wait for 3-4 weeks to get back your
favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem.
You have several ways to receive the audio signal. >Your HD tv should have inputs for DTS or HDMI The HDMI transfers all signals audio and video with on cable The DTS replaces the white/red audio. The xbox as this cables or you can buy them If you have the RED/White on your tv and you do not have enough connections.. The you can buy a (Y-Splitter Cable) They are cheap!
Hi,red-blu-green is a component signal....but red-white-yellow is a video and audio signal....component and video-audio is a different signal.You can not
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite - Video - Yellow White - Audio In - Right Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue Video - Red - Red Colors Green - Green Colors Blue - Blue Colors White - Audio In - Right
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
You need to use audio cables. Connect two red and white audio cables from the output on the HD box to the relative input at the back of TV (nr.4 in picture below). The best way to connect the HD box is by using component cables, that are the red-green and blue trio of cables, plus a white and red audio cables.
Once you have the five cables, connect them to the output at the back of the Direct TV box, and then connect the other end of the cable to either group of connectors 6, or to one of the columns in connector 7. Do connection with box and TV power off. After re-applying power use the source-input selector on remote to select the source from Direct TV box.
If you have only connected red green and blue (component) plugs, you will have no audio as these 3 plugs are all for video and all are required or you will get a black and white picture.
You currently have 3 spare slots/sockets. You need to connect another RCA type audio cable (2 plugs - red and white) from the left and right audio out sockets on the DVD player to the left and right audio in sockets on the TV. Do not disconnect any of the red, green and blue plugs to use for the audio connection!
Red is normally right and white is left, but it doesn't matter which round you connect them as long as you connect right to right and left to left. The yellow socket is for composite video so make sure you don't connect either of the audio cables to this socket or you will get mono sound.
If you need any further assistance, please let me know.
This is how the connection is suppose to be, DVR "OUT", to TV "IN" using the RCA plugs, then press AV on the TV. If this is how you connected it, then maybe there is something wrong with the video wire (Yellow).
As for the DVD, you need to connect an Audio wire separately because the component Red + Green + Blue wire only stands for video. Audio is Red and White, this must be connected for you to get sound from the DVD.
To connect the Audio for your DVD player, connect Red and White wire to Audio "OUT" of your DVD player, to "AUX" in of your AVR 146 receiver, then select AUX on your receiver and sound will come out from your DVD through the receiver.
I hope this is not complicated for you. This connection is simple, all you need is to understand the basics which is OUT and IN. If you want to watch DVD on your TV, this means the DVD will be good OUT to IN of the DVD. The same goes for audio.
If you don't understand, please let me know so that I can direct you further.
Hi, This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video. Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb Plug each pin in same color to get color picture.
You should be able to hook it up with a component video cable. A component video cable is a cable that has 5 color coded RCA style ends that are Green/Blue/Red/White/Red. The Green, Blue and one of the Reds is for the video and delivers the signals needed to produce the HD picture and the White and the other Red is for the audio to provide you with stereo sound.
The Video cords will plug into the section labeled component video facing up and down and the audio will plug into the side by side section. So if you plug into Component input 2 then you would plug in the audio into the audio section of input 2.
If you have a separate surround sound system you can connect one of two ways. 1. Plug a separate Audio (red/white) cable from the Blu Ray to an available input on the surround sound.
or
2. Plug all inputs into the TV (as noted above) and then plug a separate Audio (red/white) cable from the tv labeled "Audio Out" to an available input on the surround sound system.
You need to also connect the RCA audio out (red/white) from your source to the audio input on the TV. You do not need the yellow wire as that is for composite video. The component cable (red/green/blue) is only for video. Look at the input on the TV where you connected the red/green/blue cable. Right next to it, you should have another red and white connectors for the audio input. Connect that to the audio out on the cable box.
Are the yellow, red & white cables RCA phono plugs?
Yellow = Video
Red = Right Audio
White = Left Audio (mono)
The red, blue & green cables are for picture only and don't include sound. Have you tried using the red, blue & green for the picture and using the other cable, red & white for just the sound? Don't use the yellow.
