Hi if the problem is just some of other stations do not have sound their might be a problem with the source signal which is coming from the stations. try to turn off the receiver and then after a while turn on check if still the same station that you look has no sound if it is the case there will be problem in some channel stations. try also to hooked the speakers to the other output in your receiver. make sure all wire connectors properly fit and installed.good luck thanks for consulting the fixya.
