Kenwood VR-407 Receiver Logo
Posted on Jul 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to hook to reciever to tv - Kenwood VR-407 Receiver
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Jul 10, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2765988
Points
24828
When watching cable tv we are not getting any sound from the speakers. We do get sound from all the speakers when watching a dvd or listen to the stereo. I have a Yamaha HTR 5660 receiver. All the cables...
Your best bet is to hook all your video components directly to TV, using your TV's menu to choose what you want to watch, and then hooking reciever to TV via digital optical out from TV to digital optical in on reciever. From what I read, your reciever has 6 digital optical inputs. Anyway, try running, at least, your cable box to TV, best by HDMI, the run digital optical out to reciever. Make sure you go throught he recievers menu to make sure you have he right channel selected for audio.
Denon AVR 1609 7.1 Channel Receiver turns on but i get no sound thru the optical to the tv. what could be wrong?
If you have your video equiptment hooked to your reciever input, then, out to TV, This isn't the best way to go. Of course it depends on what you have for input and output on your TV but, the ideal way to hook your system would be to hook all video equiptment to TV, ie:, cable/sat box, DVD player, etc., to TV via, HDMI, Composite, RCA, etc., then run your digital optical out from TV to reciever. You would use the TV's menu to choose what you watch and would only have one input(audio) to reciever. Some recievers are set up to transfer video, but, it uses more cables, creates more connections, and more room for error.
1helpful
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
1helpful
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
1helpful
No tv sound through reciever's speakers. How do I hook up?
TV is not customarily a sound source. It is a video destination. Get your TV-related audio to the receiver from the same places the TV gets it - each source device's audio outputs.
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the...
try to be a little more clear on what you are trying to do.do you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Hooking up a tv to a surround sound and to a dig cable box
Ok, hook the cable box up to the reciever audio/video, find the monitor out from the reciever and plug it in to the TV input. sound will come from the reciever this way onto your speakers and the Tv will act as a monitor
Very low sound on TV and DVD no tuner
audio out from your tv to your reciever gives low output? how do you have everything hooked up i have vcr to tv dvd to vcr audio to my reciever and vcr tv thru piggy back plugs therefore i can only have tv audio or reciever or both
Connecting up
Easy set up, Hook up all the components to the back of the TV normally and then use a stereo cable from the tv to your reciever.
Usually on the tv it says audio out or variable audio out, this will go straight to your reciever on one input allowing all devices on your tv to be hooked through your reciever on one cable and the sound will come from the tv and reciever at the same time or you can turn the audio off on the tv., you can also hook up any optical audio outs from your devices to your reciever as well. This will allow for surround sound to your reciever.
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
