SOURCE: Proper mixture ratio for roundup weather max commercial grade.
2 ounces per gallon. you can convert gallons to liters on the net.
SOURCE: I can't get the Roundup Professional Sprayer to
Put a little wd-40 or light oil down in the plunger shaft to get the leathers on the pump plunger to seal back against the cylinder wall. Work it a little and u will feel the pressure come back. Maybe some dish soap would work too if u like bubbles.
ballping
SOURCE: I have 2 sprayers one
Um what do you mean by not working. spray not killing weeds, or sprayer itself not working???
Sprayers clog up if not cleaned after each use, try cleaning the entire sprayer.
FRED
