The oil pipe is poorly fitted to the oil pump and allows bar/chain oil to sneak past the seal. Buying a new oil pipe may not fix the issue since this is common on brand-new saws. Warranty work probably won't help you.
How I fixed my saw: I bought two small O-rings about the diameter of the oil pump and fitted them to act as hose clamps around the oil pipe. See attached picture. It worked perfectly and now my saw runs out of fuel before oil. Sears/Craftsman have a great video on how to remove the clutch assembly.
If is new problably it has chain lubricating oil.So whe useing the saw oil pumps out to do the job.So check out the oil.If no oil brought the saw to the store for waranty.
If you need more help post back!
Thumbs and testimonial are welcome!
