"F35" means Analog Pressure Sensor Failure
If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
Hope this helps.
SOURCE: what does F35 mean on
F35
If this failure is displayed, the Central Control Unit has detected
a malfunction of the analog pressure sensor
Possible Causes/Procedure
Check if pressure hose is fixed correctly and without holes
or damage.
Check if the airtrap is not blocked.
Check if the hose is not blocked
Damaged or faulty sensor.
SOURCE: what does code f35 mean
I found this for you:
"F35" Analog Pressure Sensor Failure
Hi
There is only one Analog Pressure
Sensor Switch Part no. W10156252, another one that it has is the water level switch (part
no W10415587). I believe you are
talking about the first one as that is what error code F35 means (ANALOG
PRESSURE SENSOR FAILURE). Hope
this helps...please post back for further assistance.
Daniel
