SOURCE: The stand by timer flash 9 times stop and start again
you have a regulator problem my friend in the power supply or there is a fault in the G board. This is not a repair an untrained person should attempt, please get a pro to assist you in this repair.
SOURCE: Sony Wega Blinking Standby Light
No... we got it to come back on and now we havent tuned it off since... we just leave it on 24 hours a day!
SOURCE: How to turn on Sony Trinitron without a remote control
Good day.
Please check with the channel buttons of your unit. They replace the power buttons functions.
chris
SOURCE: Sony KP 51HW40 Rear Projection tv red flashes
The +5 line is either shorted or overloaded on the A and B boards that what the 6 blink error code is indicating.
SOURCE: Sony kv-40xbr800 won't turn on, blinks 6 or 7 times
My tv kept getting 6 blinking lights and sometimes 4 and 7 blinking lights. So I first changed IC504 (5v reg) and the caps near it C530 and C540. It turned on a couple of times and then it stopped again within 24 hours. then I changed IC5001 AND IC 5002. still no luck. then changed C6503 AND C6590 capacitors with (1500micro f 250V because local store did not have 1200micro f 250V) they were a bit bigger and did not fit so I used 16 awg copper wire and made about 1inch legs so they would reach. I also changed C6546 becuase I saw that black goo on it and firgured it wouldn't hurt to change. still no luck. Then I changed IC6501 with a spare I had that did not work. I replaced the original ic6501 and took my spare placed it in ic8002 and the tv turned on. It still is less than 24 hours but it is on. I am going to order two new IC6501 AND IC8002 and replace both and hopefully it will last. any questions or suggestions feel free to contact me at [email protected]. even if it is a long time from now I do not mind helping. Thanks everyone else for your help in figuring out a solution!!!!!!!!!!!!!!!!!!!!!!!!!!:)
