Turntables usually are spun by a 'rubber band' type of arrangement. Look under the platter for a broken belt that would attach to a drive motor and then around the platter. I would contact the manufacturer for the correct belt. You know records are making a huge comeback.
Sorry, From Left to the Right for the blade...then 1/2 turn to offset blade out of the way to disengage....don't forget to put blade back to correct position !!
check the feed dogs to see if their up, you can see & feel them with your finger under the needle plate.
if the feed dogs are not up then somewhere in the cleaning the knob or lever got moved, go back thru what you did to find the feed dog knob,,it's always good to know where it at
You will need to lift felt on the platter section exposing the platter. Next you will need to pull upwards on the platter itself. The rubber band goes around the inside of the platter and onto the spindle motor. To replace, simply lift platter section of the unit, place the belt around the inside of the platter and replace the platter. Move the platter around till you see the motor and use some tweesers to pull the belt over the motor. Hope this helps
Hi There. If the belt falls of the platter, it might be an indication that the belt has stretched and is now too large. Or maybe it just fell off for any other reason. Remove the rubber mat, and pull upwards on the platter to remove it. Sometimes there is a small "C" clip on the center spindle that has to be removed first. (use a small flat screwdriver to remove) Turn platter over, and put rubber belt around diameter ring on underside of platter. It should be snug, and not fall off when you turn platter over. Put platter back onto turntable, and spin by hand until you see the motor shaft through one of the holes in platter. With a pair of tweezers - or crochet hook, put belt over shaft. You're done. Put back rubber mat and give it a try. Good luck, Fred PS: If there was a "C" clip, you can re-install it - or throw it away.
Place the rubber band around the turntable and put a paper clip, bent up behind the rubber band. Start the turntable on it's spindle and you will be able to view that drive spindle on the right side, slowly pull the rubber band with the paperclip and drop over the drive spindle. remove paperclip and push turntable down seating it and replace the lock snap.
The belt is usually directly beneath the platter (the part your record sits on). If you lift this up and out of the way there are two wheels, a small one from the motor ( less than 1" in diameter) and a larger one (usually more than double the size of the small one). The belt goes on around both of these. So the setup looks like a rubber band between 2 fingers...
ahh! same thing happened to me during a move. quite frustrating, but a simple fix:
remove the plate and look at the underside. here you'll see a ring around it, place the belt around that ring. there are 5 holes total, one small in the center, two larger ones to the side, and two rectangular ones on the edge.
as you're putting the plate back onto the player, grab the belt through one of the rectangular holes and place that part of the belt around the cylindrical moving post to the upper left the same time as you put the plate back in place.
it sounds confusing, but it's simple, i swear. let me know if i can clarify anything for you.
