Yes it is possible for a PS 1 disc to be faulty and not work at all. I had that problem with one of my PS 1 disc's was not working so I had bought a second disc of the same game for my PS 1 console and it was working. Try buying a new game disc to see if it works or not if it works then then it was just a faulty disc if it doesn't work at all then your PS 1 console is having a problem with the laser and the lens and the disc drive that needs to be replaced. If it is working on a different system then it could be your PS 1 console. Try a new disc and see if it works first.
Does that disc work on other players? Do other discs work on your player?
If you tell us more about the player, the disc, and what happens when you try to play the disc, we'll be able to make better guesses about what the problem is. Can you play other discs? Does that disc work in other players?
Not having specifics, here are some ideas, in the order in which they popped into my head:
1) That's a Blu-Ray disc and you have a DVD player.
2) The disc is dirty. Take a wet cloth (or paper towel), put a little dish soap on it, and gently swipe the shiny side of the disc from the center of the disc to the edge (don't wipe the cloth around and around the disc). Rinse the disc with cold water. Wipe with a soap-free wet cloth. Rinse again. Wipe with a dry cloth (or paper towel).
3) The disc is scratched. Some players handle scratched discs better than others. There isn't much you can do here. There are kits that can repair some scratches, but the kits aren't free, and they don't work a lot of the time.
4) You are putting the disc in upside-down. The side with the printing on it has to face up.
5) Your DVD player is dirty. Open the disc tray and blow as hard as you can into the player. Try not to blow any spittle into the player.
6) Your DVD player is broken.
7) Your disc is NTSC (Japan/US) and your player is PAL/SECAM (the rest of the world). Or vice versa.
8) There is some thing about region codes which is some kind of copyright protection scheme that means not all discs will work with all players.
9) Your disc is a CD, not a DVD. (I think most DVD players can play CDs, though.)
10) Your disc is DVD-ROM, meant to be used in a computer.
Check if you can hear the xbox disc drive spin up when you insert a disc to make sure the drive isn't broken. If it spins up but can't recognize the disc, try using a friends disc that you know works in his xbox. If his disc works and yours does not, try getting a disc cleaner found in most Best Buy or other disc/electronics stores. If that does not work you will most likely have to contact Microsoft Support to send the xbox in for repairs to the drive.
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
That might be something related to your Xbox 360 console itself or the disc you are trying to play on, so first have a look on the Xbox 360 game disc itself and check whether there is any kind of scratches or flaws on it.
If you find a scratch or a flaw on the disc that seems to be the reason and just to check it you can put any other game in your Xbox 360 console and try it once more, if the other game is working fine that definitely assures that it's a fault with the game disc & check on the scratched discs page on our web site for more information about the reason for this issue to occur.
In case there is no scratch or a flaw on the game disc try the following steps: 1- With no discs in the disc tray, go to the System section on the dashboard. 2- Select Console Settings. 3- Select Start Up. 4- Make sure it is set to Disc not dashboard. If it is set to dashboard, select Disc and try the game again. It should work. If is already set to disc or you tried setting it to Disc and still not working try the following steps: 1. Just clean the disc & put it back in your Xbox 360 console and see whether it's going to work again or not. 2. If it's still not working try also another discs to know whether it's an issue with the actual Xbox 360 console then or not. 3. If the other discs work fine you can try it then without the hard drive because it might also be something related to the hard drive. 4. If it is still not working so this game disc would be for sure faulty and you have the right to exchange it from the retailer you bought it from as it's not scratched.
In all cases if other game discs are giving you the same error message "To play this disc, put it in an Xbox 360 console" you need then to contact Xbox 360 customer support to send your console to get repaired or exchanged.
Have you checked the disc for smudges? It sounds like you have a dirty disc. If that's not it, have you tried other discs in your Wii? If the disc worked before, it should still work, unless:
A. Disc is dirty B. Disc is scratched C. Wii isn't playing any discs
