You have two options:-
1. Try every possible combination. Although there are 1000 of them it's going to take less time than you think as you won't need to go all the way from 000 to 999. usually for a three digit lock it takes less than five minutes and shouldn't take more than a maximum of about ten minutes.
2. You can try to hack the combination. All similar locks (including four or five tumbler versions) can usually be opened in less than a minute when you have the knack. Pull the lock apart as if it had the correct combination and keep the tension on it. One of the tumblers will be harder to turn than the others so start with that one. Keep turning until you fell a definite change in resistance on one number and then repeat with the next most difficult to turn tumbler. On your lock you only have to do this twice, the third and final one will just be a case of turning until the lock springs apart. Don't expect to perfect the trick instantly, but after a few goes you'll definitely get a feel for it and then be amazed at how useless and insecure most combination cable locks are. An experienced thief can hack them in easily under 30 seconds.
Safe and happy travels.
how to reset Promax combination luggage lock
i need english driver i
machine error 0410
how can i install skype on my mobile samsung corby gt-s3653?
my nec vt460 no display power light red on
smart phone
Sky remote code for remote code for toshiba regza 42zv635d
Had no problems, Brand New battery which is tightly fitted and screws are secured. I started to drive it and it began to **** and jump around when I gave it Gas then once I got home it stalled out and now will not turn on, but everything still works and lights up so I know its not a bad battery.
printing envelopes
vertical lines on prints from feeder but not on prints from glasstop
GOM Media Player serial
2005 mazda tribute gear
cant cancel document in print que
press telephone buttion - com.android.phone is not responding
why my pioneer plasma 42" tv keep switching itself off ?
location of pcv valve
stalls after reaches operating temp is not driveable to engine is cold again
don't come on
Voltas Vertiga Elegenat Model
candy crush game and farm heroes saga will not load on my laptop. Just suddenly stopped working
Solenoid valve was replaced. Pump immediately started flushing several times an hour. The unit has been leaking for a few weeks unnoticed (carpet was destroyed). HVAC company advised me that needle should be fully opened but the flow seems excessive. Humidifier is a GeneralAir. Pump model 554401
my 1992 century wont turn over its not the battary it has automatic starter
uninstall cabal helix
open dxr file
jeep liberty interior lights not working
pc america rpe
truck will not engage in 4 wheel drive
installed battery in 20o3 neo but starter turns motor very slowly, fortunately the motor cranks quickly. thinking it may be the starter dragging. how do you replace the starter on this car?
Have checked all pipes no blockage goes through all the cycle but wash button constantly flashing when cycle finished clothes are soaking wet not spinning properly and not draining water.
Kodak all in one C315 prints gray but not black. I have replaced the ink cartridge and it shows full but will not print black Sometimes I get an error code 105-3527
HAVE MINN KOTA ALL TRRAIN 40AT/H. REPLACED WITH NEW SWITCH. CANNOT GET BUT 3 SPEEDS. ALSO SMALL WHITE WIRE LOOKS BURNED. HOW CAN I REPLACE IT AND ALSO THE SMALL YELLOW WITR
engine surges at idle
When I take the key out, the ignition keeps beeping, even with door shut
check engine light on indicates possible sensor
I had a transaction of R149.95 going twice from my bank account on 31 December 2013. It was reported to Standard bank on 4th January 2014. After several phone calls and visits to my nearest branch which is costing me now more than it's worth. Nothing happens. Last month I was informed that the first person never executed any work on the problem and the branch I visited will now solve the problem. I'm still waiting. It is now almost 3 month later, a problem that they say would have taken 12 working days is still not solved. Nobody phone you back, every phone call you make to customer care ends up costing you a fortune. I want to know how much money must you spend to get back a lousy R150 that was stolen out of you account. I don't have a lot and is not prepare to loose money that belongs to me. I want my money back.
