Motorola CP040 charging time
The rapid rate charger WPLN41__ will typically charge a battery in 90-120 minutes. Your battery should be depleted or nearly depleted when you place it in the charging stand. Be certain your radio is always turned off, when charging an attached battery. The NiMH battery will generally go 12-16 hours on a charge when new. If you work an eight hour shift, you might see if the radio will go 2 days on a charge. Later as the battery ages, you will need to charge it nightly. (Think of putting it in the charger as putting it to bed at night.)
Rapid charging is necessary on NiMH and Li-Ion batteries. They require a "hotter" charger, a fast rate, to completely charge the battery. It will not harm this chemistry of battery. It is safe to leave the battery on the charger overnight, or for a weekend. We would not recommend leaving the battery on the charger longer periods of time, as that will age the battery and reduce its life.
(Sidenote: Frequent rapid charging will however reduce the life of a NiCD battery.)
