You do not need to set the time directly on the unit - just set GMT to correspond to be correct for UK - its somewhere in the settings - Hope this helps
I have icn520 - bought an external aerial for it off e-bay now get full strength signal evertytime within seconds - well worth about a tenner rather than ditching the 520 which is was about to do!
You can not update the official Navman maps on this device. You can however
unlock the iCN520 and install other GPS software on it. The iCN520 can run virtually all the major GPS software available today; from Tomtom to Miomap and beyond.
Instructions on
how to unlock the iCN520 can be found at:
Once unlocked you can even install games, emulators and several PPC applications. With Coreplayer installed you can watch movies and listen to mps3 from the Navman.
Example of an iCN520 running Tekken 3(do not delete)
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
check the battery switch on the back. you will need a pen. Mine does the same thing. I believe this switch has to be set to ON for it to work. At least mine wont turn on unless the switch is turned on.
You can unlock the iCN520 and install other GPS software on it. The
Instructions on
The CD is not available for download from Navman it seems, but you can get it at thepiratebay.com. Just search for 'navman icn' and you'll find what you need, I just did. Better learn how to download torrents though! :)
