Hi
Just try with component input, and see whether it works fine. If it works fine with component input, the tuner section in your TV has got damaged. Soem Vizio sets will have dual tuner; one for analogue and the other for digital. Lighning stroke will damage the tuners first, than any other components inside a TV, because it has been alway connected to cable. Check the component video. If it also does not work, the mother board of your TV is faulty. Some type of fault will be repairable. If the fault is serious, you have to replace its main board istself. OK.
I had the same problem with my Vizio SV370XVT when my digital Comcast boxes in the house got fried. My HD ports on the tv are trash now, but I am able to get an HD signal via the component port. I tried replacing the main board, but that did absolutely nothing. I just gave up and purchased a component switch. I was at my wits end looking for an answer but your response helped finally. Thanks!
Thanks to knowing that my solution was helpful for you Julia
Ajin
https://www.amazon.com/Charm-2Pack-4-9Feet-1-5Meters-Lightning-Connector/dp/B01DU8UQR0/ref=sr_1_10?ie=UTF8&qid=1483672440&sr=8-10&keywords=Charm%2Bsonic&th=1
