SOURCE: Compatible processor 3.0 HT with 845gvsr board
Here is a page from Intel listing all of the compatible processors for your board:
845GVSR Processors
There are a couple of 3.06GHZ CPU's listed.Verify the other specs. or processor number to be sure.
SOURCE: I have Intel 845GVSR Motherboard, 2.4GHz Processor, 1GB RAM
Yes it will. Just make sure to buy the proper hdd. If your board has SATA II connections then you would need a SATA II hdd. If it is just SATA then a SATA II drive would not work. Your other option would be an IDE hdd. If your system has a cable that looks like a big ribbon connected to your existing hdd then it's an ide drive. Hope this helps & please remember to rate my answer. Thanks.
SOURCE: i have intel 845gvsr motherboard so iwant to buy a new intel processor which is compatible
Although not quite what you need, but you can find a comprehensive list of the type of processors that your board support from the link below:
http://support.intel.com/support/motherboards/desktop/d845gvsr/sb/CS-026968.htm
Some further recommendations, the board is pretty old as it seems to fit Pentium 4 chips only. You may want to look at buying boards which suits a dual core at least.
SOURCE: Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
SOURCE: Display Problem with Intel 845GVSR
Reset the CMOS setup after putting the battery. You have 768MB RAM. So check with the alternate memory module with different slots. If not helpful, check the RAM with another PC. Lastly get the BIOS updated or motherboard repaired from component level motherboard repairer. You may have damaged the motherboard by putting undue pressure while plugging the connectors.
sonsunny
