V/mail indicators do not flash when messages are waiting for review on rca 25202. batteries are good, they are programmed successfully to call in to retrieve v/messages. why no flashing?? manual indicates they should do so. thanks
If this is a system-wide problem affecting all phones then the voice mail integration is not programmed correctly. If this problem is affecting only 1 phone, then the VM message waiting function is disabled on the user's voice mail account or the status of the user's message waiting light is out-of-synch with the VM controller (Light on when the system think's it's off and vice-versa). Contact your system support person or service company for further assistance.
~*~*~ SOLVED SOLVED SOLVED! ~*~*~ After talking to both ATT and RCA with no success...I figured it out. ~*~*~ Plug your phone line into the "DATA PORT" on the back of the unit. Slide the "DATA PORT" switch to whichever line is showing it has a message. Press the corresponding Line# button on the front of the phone. (you should hear the dial tone) Dial your voice mail number. Let it answer, (enter your passcode if needed), then hang up! - That's it! example: MSG Waiting:L2 - I plugged the phone line into the Data Port and moved the data port switch to "2". I pressed LINE 2 on the front of the phone, dialed my voice mail number, it answered, I put in my passcode. (It said that I did not have any new voice mails), then hung up! That's it! Message Indicator light off!!! Repeat for each line that shows a (false) message waiting. ~~~Don't forget to move your phone line back into it's correct port on the back of your phone.~~~
The term we used for this back when I worked for the phone company was a "stuck message waiting indicator" and the way to fix it was:
Call yourself and leave a message. Hang up and wait 2 minutes (we used to say 5 minutes, but 2 is plenty) Retreive/delete your voice mail message Hang up and wait 2 minutes
This feature is country dependent and may not appear in some countries. If you have subscribed to the voicemail service from your local service provider, icon turns on when you have a new message in your mailbox. After you have accessed to all the new messages, icon will turn off automatically. If you find that the message waiting indication cannot be turned off by the network, you can still turn off the message waiting indication with your phone by the following step :
In idle mode, if voice mail waiting icon is on, long press the redial key to turn off the voice mail waiting icon. Once you choose to delete the message waiting indication, all the other handsets registered to the same base station will turn off the message waiting indication accordingly.
Don't know about other models, but I just called RCA small business phone support (800-511-3180) to find out how to clear the message light indicator on my 25210 2-line cordless phone when it continues to blink but there is no message.
All you have to do is hold down the delete button for a few seconds and it will clear. Hope this helps someone else from going batty!
I recently changed my number and when I did, I received the same problem. It appears that AT&T didn't add the Message Indicator Light service to my new number. Once they did, the message light works!
Try calling your phone service provider and asking if they have a Message Indicator Light function.
That blinking indicates a message in a third party voicemail (voicemail provided to you from your phone company), contact them as they may be charging you for a service you do not use.
Charge/in use indicator on the base flashes
• Provided your phone company offers voice messaging service and you subscribe
to it, the charge/in use indicator on the base flashes when the phone is not in use
to indicate there is a message waiting. It stops flashing after the message has
been reviewed.
I bought this phone from a second hand store and I bought it for the hold, and intercom feature. I plugged it in and every thing is working fine. one thing that i noticed when you call the phone it picks up and you hear nothing, what can I do will I be able to be use it as a home phone. I was looking for a instruction manual can you help me out with that. Any help would be thankful for.
