Is it possible to manually focus the C-5500 Sport Zoom?
Occasionally it is necessary to have the ability to manually focus a digital camera. A good example is shooting through the windows of a tour bus on a rainy day. The camera may choose to focus on the raindrops on the window rather than the actual subject. To enable the MANUAL FOCUS function hold down the OK/MENU button for a second or longer. In the lower left corner of the LCD screen you will see MF (MANUAL FOCUS) and AF (AUTOFOCUS) with AF highlighted in green. Use the left arrow key to select MF. You will now be able to use the up and down arrow keys to manually focus the camera. An added feature of the C-5500 is that when you are using the MANUAL FOCUS Mode you will see a magnified portion of the image in the center of the LCD screen. To get out of MANUAL FOCUS Mode, simply use the right arrow key to reset the camera to AF. Then press the OK/MENU button to return to the default functions.
