Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
jim stephens Posted on Jul 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model 2254 deck belt jumped loose, need diagram as to how it winds "top view"
Anonymous
Level 2:
  • Expert 252 Answers
  • Posted on Jul 08, 2011
Anonymous
Expert
Level 2:
Answers
252
Questions
Helped
173682
Points
510
Hi there senator359
pauly46 here
please find web site for a manual that has belt roueting in it
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_O0802053.pdf
it is lgt2654
go to web site down load and print
here is husqvarna gth 2254 web site for diagram
http://www.partstree.com/parts/?lc=husqvarna&mn=GTH+2254+XP+(96023000201)+(2005-06)&dn=86020023
check them both out
let me know if helps
dont forget the thumbs rating
cheers pauly46
Cub cadet m60-kh the PTO belt keeps jumping off
https://www.partstree.com/parts/cub-cadet/mowers-zero-turn-lawn-mower/m60-kh-53ab5bdx750-cub-cadet-commercial-tank-zero-turn-mower-27-hp-kohler/fabricated-deck-spindle-assembly/
Likely the deck idler pulley is loose or bearings are shot. The pulley should not wobble and the flat side of the belt should ride square against the pulley face (the pulley should be reasonably perpendicular to the deck). If not, the idler arm pivot is loose or the pivot bolt and arm are shot. Check proper tension is applied by idler pulley torsion spring (the belt is not loose).
c1-rh14230rqgibnrzrzz3yshgm-3-5.png Comment here and Ill assist further if need be.
I need a diagram showing how to route a mower deck belt on a John Deere model 240 mower deck. My spring has fallen off and I need to know where it goes to put the tension on the belt.
Here's a link to an online John Deere parts store. When you land on the page, look at the top sub categories for the size of deck your mower has. You should be able to access a parts diagram with pictures of your belt's proper placement.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
I need a diagram for deck belt on a 1989 lawn boy lt 12 38 " deck
it's usually on top of the deck clean off the grass and look on top may have to remove it to see
2helpful
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
I posted the below problem last night with the request for additional information reply sent 2 hours ago. I need to use this mower today. I need to have an answer. THanks Problem with the...
Thought I posted a solution earlier on this, but it was my first post and I don't see it here so I'll try again.
Google search on your model shows the drive belt diagram on page 27 of the manual.
link below:
http://www.mytractorforum.com/images/reference/dgs6500.pdf
Looks like mine.
basically need to remove front pulley by loosening center bottom bolt while holding the center nut on top of motor.
Slip belt over the rear pulley first and then straight toward the front, slip belt on front pulley and then slide pulley back onto shaft.
Then wind through the rest of the pulleys etc..as seen in the diagram.
2answers
Can i have a belt diagram for a john deere stx38 please , thanks pete
Click on the above link then do a "model search"
click on which model (either yellow deck or black deck)
alphabetically pick which belt,
a diagram should appear in the right hand corner.
Or you can try the link below.You will need to sign up(free I think)
http://www.pdfph.com/pdf/john-deere-1999-stx38-hydro-deck-belt-diagram/
The link below has a picture of the belts on a yellow deck.
http://www.askmehelpdesk.com/tools-power-equipment/installing-belt-jd-stx38-hydro-385391.html
6helpful
3answers
I need a diagram of the belt on a black deck John Deere STX38 can you assist Thanks Deb
Follow this link: http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt then do a "model search"
click on which model (either yellow deck or black deck) alphabetically pick which belt,
Or this website:
OutdoorPowerInfo.com © 2011
Or just 'google':
Installation of John Deere STX38 and STX46 Hydro Drive Belt (Black Deck)
Good luck.
14helpful
3answers
Need diagram of deck belt installation
May I get the make and model # to get you the right belt diagram
Belt jumped off pullies
The deck drive belt makes an L shape looping to the the outside deck pulley that has 2 pulleys. The deck drive belt rides on the top set. X = pulley engine x
l l
l l
l l -
l l x x = outside deck pulley
back deck pulley =x
motor to idle to outside
motor to tension to outside back side of belt goes around idler
4helpful
2answers
Belt broken on riding lawn mower (john Deere LT 133) need belt routing diagram
This link will send you to the illustrated parts list on the john deere site. It shows the belt routing in the part diagram. Hope this solves your headache.
Mar 30, 2009 • Garden
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
