HP Photosmart C5580 All-In-One InkJet Printer Logo
Posted on Jul 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just replaced an ink cartridge and the printer keeps telling me to load paper then press OK, but I already have paper loaded. The machine keeps trying to pick up the paper, but unsuccessfully.
Anonymous
Level 2:
Sergeant:
  • Expert 210 Answers
  • Posted on Jul 07, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
210
Questions
Helped
114011
Points
556
Hi, Please check the paper and the paper tray. The paper or the the paper tray is inserted properly. Turn off the printer and turn it back on after 10sec. and try to print that should work. Please get back to us if this information helps you solve the problem.
1helpful
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
2answers
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Paper will not feed through after replacing color
Good day, I suggest you must clean the roller and and use appropriate type of papers. to clean the roller, press power button to turn on the machine then remove any paper from the auto sheet feeder. press menu until maintenance appear the press ok. and try to load load 3 or more a4 letter sized paper and see if the the paper is automatically fed in and then out of the machine.
hope this will help you. have a nice day.
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
1helpful
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Paper Jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
3helpful
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
Printer telling me to remove and check right bay ink cartridge on hp 2410
Just some ideas you probably already tried: 1. make sure you took off the bit of paper / tape covering the vulnerable bits. 2. try another cartridge and/or a friend with similar machine & cartridge 3. make sure you load it correctly: only when machine is turned on, the slight overhang at top each side aligns with grooves, and you are reading the number OK from the front = it is in the right way (deeper end at back). 4. Keep searching different Google reviews and knowledge bases- with different questions.
k24674
Grand Canyon Tech
Grand Canyon Tech
