Chevrolet S10 Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 4? x 10?
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
you should just be able to get an adaptor harness, if the plugs are cut then good luck its a real pain. for some reason other vehicle wiring is added into those harnesses
A picture requires an installation, which is what you are doing. You should invest in a vehicle specific wiring harness. The wiring colors match for the connection and said harness then plug into the factory harness. If the factory harness no longer exists then you need the wiring diagram for the vehicle. You mention the vehicle has a premium stereo, the Metra part number is 70-5510. It's for an amplified system.
It is best to buy a connector pigtail for Ford, but you can wire directly using the below color code for the factory wiring. use the color code from the pioneer to match to the factory wires. If you have more questions, please reply.
1994 Ford Aspire Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red Car Radio Accessory Switched 12v+ Wire: Blue/Yellow Car Radio Ground Wire: Black/White Car Radio Illumination Wire: Red/Black Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: Light N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 5 1/4? Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Brown/Black Left Front Speaker Negative Wire (-): Green/Red Right Front Speaker Positive Wire (+): Green/Orange Right Front Speaker Negative Wire (-): Blue/Orange Car Audio Rear Speakers Size: 5 1/4? Car Audio Rear Speakers Location: Side Shelves Left Rear Speaker Positive Wire (+): Blue Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Pink/Blue Right Rear Speaker Negative Wire (-): Brown/Red
Just look up the stereo wiring diagram for your chevy and splice the wires together. Here's a site that has it http://www.the12volt.com/installbay/stereodetail/476.html
All you need to do is go to the parts store, and get a wiring kit for your vehicle. It will plug into the factory harness, and the colors on the new pigtail will be same as the aftermarket c/d player. Hope this helps.
Your gonna need to find out your trucks wiring schematics to get this one going. Get a copy of a Chilton/Haynes manual (free at a local library) and scope out the dash/stereo wiring diagrams for the truck. Go to Pioneer's website and enter in your cd player model info etc to get its wiring info.
