Microwave Ovens Logo
Posted on Jul 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I repair the door latch for a Sharp Carousel R-530ESF microwave oven? The push button won't open the door. I had to use a putty knife to push the latch up and open the door.
William Miller
Level 3:
  • Microwave Ovens Master 9,179 Answers
  • Posted on Jul 10, 2011
William Miller
Level 3:
Answers
9179
Questions
Helped
4479468
Points
21747
The service manuals are at our site here and here.
You can order parts from the Sears Parts Direct Web site How do I repair the - image-4235112-10659157 or Encompass here.
How can we fix the door of our Sharp Carousel Convection Microwave Oven Model R-9X56?
This appears to be an Australian model and these are the only spares I can find. They do sell the latches. If the hinges are damaged and causing this, you will feel movement. Looks like it is time for a new one.
https://spares.bigwarehouse.com.au/index.php?cPath=46427_53341_57047
https://www.google.com/search?q=sharp+R-9X56+replacement+hinges
Sharp carousel door often won't open when I push the door release button in.
Take the cover off end take a look how the hinges are mounted on it, If they are bolted on they can be readjusted, He man, Use your brain .
4helpful
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
1helpful
Sharp carousel microwave R216 LS door latch has a problem. It won't open and feels like there is just a spring inside. I dont know if I can open it and fix it.
It's probably a broken door open lever or door open button.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
2answers
I have a Sharp Microwave Carousel R-420B. I put a bowl of soup in , closed the door, pressed Minute Plus, and hit Stop with approx 20 seconds to go... pressed the door release but nothing happened... door...
Usually, the door lever or hinges is the cause of this type of problem.
But in this case, I don't think the door lever or hinge is the cause of your problem.
I think the door is jammed and only needs some force before is can open or unjam.
Use your hands or a flat Philips screw driver to forcefully open the door. Don't apply too much force. Just apply a reason amount of force that could open the oven door.
Before you attempt to forcefully open the microwave door, leave it for about 45mins to 1hr, after that forcefully open the door.
If the above doesn't help to open the door, please let me know so that I can direct you further.
I wish you good luck.
Regards.
Mine does this occasionally, and it's because the door hinges have got a bit out of line, allowing the door to drop slightly, so the catch mechanism won't quite disengage.
Look along the bottom edge of the door and see if it has dropped lower than the front panel next to it. Try applying a bit of upward pressure on the bottom edge with your fingers, while pulling towards you at the same time, and with your other hand press the release button.
If that gets it open, remove last night's failed meal, open the door fully and carefully force it up a bit at a time, to bend the hinges back to level - keep pushing the door back so it nearly closes, and look at the bottom edge to check on progress. When the bottom of the door looks level with the panel , try closing it fully and see if the release button will open it again.
2helpful
My door latch pushes in but does not open the door.
But does not what? If the door doesn't open, chances are the seal has gotten sticky so try to apply a little outward pull... If it is sticky and opens, wipe down with moist cloth both the seal and the mating surface.
8helpful
2answers
Plastic latches on door have no tension. Microwave thinks door is open, because latch is not ingaging. How do I access the latch hardware.
with butter knife or small flat head screw driver, carefully remove the plastic ring from ther inner door .cheap repair is to hook the spring to the metal fins inside the door if not order outer door panel
Sharp Microwave model R-1850A door won't open
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
