Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
The oven and display clock on the digital display stopped working. The oven will not turn on, the digital display is total gone as well. I checked the fuses and they are fine. I think it is electrical. Does anyone know why this would happen and how to fix it?
  • 5 more comments
  • Anonymous Aug 30, 2008
    still does not work
  • Anonymous Sep 26, 2008
    It cannot be electrical as the light inside the oven is working just fine.
    The gas on the range top is working fine, as well.
    It is the control panel - will not light up, blink or start the oven...
  • Anonymous Mar 18, 2009
    I have the same problem with my frigidaire oven. Control Panel that works the oven does not light up or work. The burners work fine.
  • Anonymous Apr 25, 2009
    My control panel is also out. Ive flipped the breaker but to no avail...I took the back off of my oven to see if there was any obvious damage. Im no electrician so im not quick sure what im looking at. My house was hit by lightening a while back so i think something has blown involving the panel...is there some fuse i should replace??
  • CCRYDER7000 May 11, 2010
    Control Panel Won't Come on, top burners work. Someone mentioned checking fuses and breaker. Let's start with the basics, where are they and how is this done? If I must replace to EOC (Elec. Oven Control), where on the over is this?
  • Anonymous Mar 22, 2014
    How to check digital clock as now oven want go.is it a fuse problem
  • V Sch
    V Sch Jan 05, 2019
    Having the same issue with my Frigidaire range...clock assembly and oven out but burners are fine. Just watched a video (YouTube) on changing the control board. I'm going to buy one this weekend and try it. (It looks like an easy fix.) Fingers crossed!
    New Friend:
My frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Posted on Aug 12, 2010
My eoc is not working on my oven burners work fine but no clock or oven controls please help
Posted on Jul 05, 2010
  • Megan W
    Megan W Apr 11, 2017
    FixYourBoard.com can fix this for you! 2 year warranty. I've attached a photo of what the display would look like after the service.
  • 116 Answers
If the oven was working before then
1. Power is gone from the unit - loose connector or neutral wire ( or ground wire depending on wiring system being used)
2. The power supply transformer (or transistor) on control board is busted. This is especially true if there was power problems in the apartment- power going on and off frequently. Check the wiring and see what comes up. Hope that helps
Regards
Posted on Sep 04, 2008
Oven and control panel/clock won't come on
Posted on Sep 12, 2008
3 Suggested Answers
SOURCE:
SOURCE: I have a Frigidaire 30" self cleaning oven that is a stand alone...the oven stopped working this past weekend
have your electronic timer sent for repairs, go on internet at ApplianceTomers.com
Posted on Nov 11, 2008
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
    Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
    Posted on Nov 13, 2012
    Bottom oven stopped working. Clock display is totally blank but we have power to the oven as grill & top fan still coming on.
    No make or model all pretty much the same oven power fed from clock/control either and open fuse feeding power to clock or bad clock have seen burnt wires going to clock
    Apr 03, 2015 | Ovens
    Belling evolution 152 main oven stopped working and clock gone out.
    Have you checked the power source to the oven? Has the cord come out of the wall plug? Has a circuit breaker tripped? Once the obvious things are checked and proven good will it be necessary to dig into the interior of the appliance.
    Oct 14, 2014 | Ovens
    My clock does not work on my stove
    Hi Jason. Have you performed the following actions?
    Electronic Timing Center (Analog Clock w/Digital Display)
    Synchronizing the analog and digital clocks
    1. Press the "timer" and "start time" buttons simultaneously.
    2. Turn the set knob to move the hands on the analog clock to any time setting.
    3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
    Setting the Time-of-Day
    The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
    1. Push and hold the "timer" and "bake hours" button at the same time.
    2. Turn the "Set" knob until correct time is displayed on the digital clock.
    3. Release "timer" and "bake hours" button
    The analog clock will automatically set after the digital time is set
    Let me know so that I may follow up if need be.
    Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
    Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
    The timer clock has gone off.
    to stop the clock area from flashing and for it to display time, the time must be set.
    Apr 09, 2009 | Ovens
    LED display stopped working
    Hi!!! your clock or control board has malfuction.You can get access from the back of the unit pull the unit out and look at the back remove the screws..Your control board clock board went bad..Good luck..
    Jan 04, 2009 | Belling XOU252 Electric Single Oven
    Electric oven & grill not working no digital clock display
    If there is a display on the clock and you cannot reset it to manual, then the oven will not work, if you cannot reset then you will probably need a new timer fitting.
    They can be bypassed, but not recommended unless you know what you are doing..
    If there is no display at all , then check to make sure you have supply to oven
    Plz rate my solution.
    Thanks.
    Dec 16, 2008 | Neff U1661 Double circotherm super...
    Frigidaire non-digital (old) Caprice top electric oven not working
    Check the clock knobs the older style you had to push in to auto time them make sure the times are on the same time (stop&start) and the buttons are popped out to engage the upper oven if so post the complete Model # and i will get the manual for you
    Jan 21, 2008 | Frigidaire 27 in. Electric Double...
    Oven Problem
    Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
    Apr 08, 2007 | Frigidaire FGB24T3A Gas Single Oven
    Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
    9,104 people viewed this question
    Top Frigidaire Ovens Experts
    Craig Butler
    Craig Butler
    Marvin
    Marvin
    Bruce Denton
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
