I'm sorry to hear about the problem you are having with your AccuGreen spreader. Sometimes we have replacement parts for our spreaders. Please give Scotts a call at 1-800-543-8873 at your earliest convenience to check part availability. Hilary @Scotts
I just spoke with the customer service rep and she was very helpful.
They are sending a new handle at no charge.
GREAT SERVICE!!!!
I'll buy anonther one for sure.
You may check the calibration by using the following directions. First, adjust
your micrometer setting to 2. Squeeze the trigger against the handle. The
calibration line is a small, raised line embossed on the top of the spreader's
shut-off plate. With the micrometer set at 2 and the trigger squeezed against
the handle, the calibration line should be aligned with the back edge of the
hopper opening.
To adjust the alignment, use a small wrench to turn the
black calibration screw at the lower end of the control wire leading from the
micrometer rate setting barrel. Adjust the screw until the calibration line and
back edge of the hopper meet. If you have any difficulty checking the
calibration, contact us and we will be happy to help walk you through the
adjustment.
When you are not pulling on the trigger handle, the cable
should be loose. When you pull on the handle, the cable becomes taut and the
shutoff plate slides open.
If you need further assistance feel free to contact us @ 1-800-543-8873
