Jet 3 Ultra Power Chair Logo
Posted on Jul 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clanklng in left drive wheel - Jet 3 Ultra Power Chair
JP Services
Level 2:
Sergeant:
Champion:
  • Expert 310 Answers
  • Posted on Jul 06, 2011
JP Services
Expert
Level 2:
Sergeant:
Champion:
Answers
310
Questions
Helped
257205
Points
607
If you block your chair up in the air so your wheel is off the floor you can check for a few things. First roll the wheel around and see if its rubbing. next see if the barrings are out if they are the wheel will woble. next see if the bolt in the center is tight. if you catch this in time it wont cost alot if any money
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jazzy 300. Tight drive wheel. Clicking naise
It's possible that the clicking noise is being caused by a loose or worn-out component within the left drive wheel of the Jazzy 300 power wheelchair. The tightness of the wheel could also be contributing to the problem.
To diagnose the issue, you may need to inspect the left drive wheel and its components, including the motor, axle, bearings, and any other parts that may be causing the clicking noise. Tightening any loose components or replacing any worn-out parts may help to alleviate the issue.
It's always a good idea to consult with a professional technician or the manufacturer of the Jazzy 300 power wheelchair for specific troubleshooting advice and repair recommendations.
1helpful
Turf mode not working
turf mode is where only one wheel is powering the sportsman.
sounds like the left wheel is the one that would drive it.
i can not figure out if it is the rear left wheel but it may be. i would see if there is a problem with that.
1helpful
2answers
My 1998 hyundai excel glx has a clicking sound front left wheel when turning
that would most likely be your drive axel when they go bad they click when you turn the steering wheel
Is all wheel dr like 4 wheel dr
All Wheel drive, you have all four wheels working at once. Where four wheel drive you can turn off to 2 wheel drive.
I have a Mazda Midge 1998 whick was damaging the left CV joint regularly. After replacement of all suspension parts I diagnosed the problem to the gearbox. Drive and all the load is only on the left drive...
hj there this is perfectly normal because the left wheel is the drive wheel on a basic front wheel drive gearbox,Check if the shaft is not bent secondly inner CV TRIPOD could be worn. Left front chassis leg could have bent due to accident or impact .Outer CV my have been fitted incorrectly.
1helpful
When in 2 wheel drive and accelerating, the car pulls to the right, upon decelerating, it goes left, it would seem to me that I have 3 wheel drive, with the rear nearside wheel still driving. What is the...
Not understanding you 3 wheel drive thing, But I believe that the Xterra are a front wheel drive based engine and if that is the case most front wheel drives will pull to right at excelleration and then to left under letting of excellerator. This is do to engine torque but if it is extensive you may want to check motor mounts.
Rear scraping sound, Also when placed on lift and in gear (all wheel drive) the rear left wheel does not spin
Take it in for proper diagnosis - that's not supposed to happen in an 'ALL WHEEL DRIVE' - all WHEELS ARE SUPPOSED TO TURN.
Top Jet Health & Beauty Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
