Umm...
We're having some confusion on the terminology here which is why I don't think anyone's responded so far.
Let's start here:
In the United States, there are three types of wiring circuits: single-pole, 3-way, and 4-way
Internationally, those same three types are instead referred to as: single-pole, 2-way, 3-way
So, when you say that you want to replace a 2-way wall switch, and replace it with a 3-way programmable timer - I think we're talking about the same type of wiring configuration - so yes, it should work.
The only thing you need to look at is that if this is a 2-way/3-way circuit, then chances are that there is another light switch that controls the same fixture, correct? Some programmable timers do not work with standard, 3-way toggle switches in the other location, you may want to investigate what is required at that spot. I would contact the manufacturer of the timer switch you're using for more information.
