Question about Canon PIXMA MP530 All-In-One InkJet Printer
Error code U052. I know this has to do with the chip in the ink cartridge. I changed all cartridges and still the same code. I cannot use any function on this MP530 with this error code.
    Sergeant:
  • 219 Answers
Please remove all cartridges. Using a moist cloth clean the golden contacts on cartridge as well as printer. DO NOT touch nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Now insert cartridges and see if error goes away.
Do not forget to rate my answer.
Posted on Jul 06, 2011
  • Louis Wees Oct 04, 2013
    Thank you but it doesn't work on my MP520.
  • Canon Master
  • 4,338 Answers
Try this:
First power off the printer. Next, while holding STOP/RESET button, power on the printer.
While holding POWER button, release STOP/RESET button. Then push STOP/RESET button twice.
Wait about 20-30 second until the LED shows "0?. Then push STOP/RESET button four times.
Finally push POWER button twice. Last step is to turn off the printer by pressing the POWER button one last time.
or:
Reset Canon Pixma MP520 maybe Work Also on Canon MP500, MP510 and MP530
To reset Canon Pixma MP520 view this article:
http://tricks-collections.com/resetting-canon-pixma-mp520/
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Canon Expert
  • 241 Answers
Resolve Canon Printer Error U052
In case your printer is not installed correctly, error u052 might occur. Go through the following steps for troubleshooting:
§First, switch off the power of your printer.
§Then, remove the lid of your Canon device.
§Next, check the situation of the cartridge slots.
§Go for installation of the print head.
§Finally, close your printer and switch on the power.
Your printer should now work fine. If the error message continues showing up, it is possibly the other issue. In that case, get in touch with our customer support center. We are sure to assist you.
If your Canon Printer is not working in spite of proper installation, it could be an issue with the computer or laptop.
§First, you should go for a reinstallation of the print head.
§Also, consider a primary cleaning process.
Dial +1-888-633-7151 Resolve Canon Printer Error 6000:
Posted on Jun 10, 2019
6ya staff
SOURCE:
Error message U052
U051 indicates an ink cartridge that cannot be recognised by the printer. Sadly you cannot use your printer while this error remains.
I would advise the following:
-Remove the problem cartridge from the printer
-Wipe the gold contacts on the front of the cartridge with a piece of non fibrous tissue (like kitchen tissue).
-Re-install the cartridge.
If the error remains it is likely that there is a genuine problem with the cartridge. So I would advise getting in touch with whoever you purchased the cartridge from to arrange a replacement.
Sep 04, 2012 | Canon Office Equipment & Supplies
When I turn my printer on it says that the type of print head is incorrect and to install a new one. I have never changed my print head and was working fine last week. I took the ink cartridges out and...
Hello.
Sometimes this is caused by the chip on the black cartridge. I know it sounds unusual but this chip is called the "master" and it identifies the series of cartridges and head to a table built into the printer. if a error is detected it can cause the message you are receiving.
If you have already removed the head, checked the contacts and replaced the cartridges, then try this link below. it may help re-set the printer. http://www.fixya.com/support/r9017204-resetting_ink_waste_absorber_error I hope this helps
Regards GM
May 26, 2011 | Canon PIXMA MP620 All-In-One InkJet...
CHECK CARTRIDGE u052
Remove all ink tanks (printer is on), remove printer ink cartridge carrier head. clean head with alcohol wipes thoroughly, not contacts. Push in gently print cartridge pistons on cartridge carrier. Reseat print cartridge and ink tanks, replace any very low ink one's. turn off printer, unplug electrical, remove usb on printer and computer. plug all back in, turn on. Alarm and message should disappear. Clean and realign with software.
Feb 07, 2011 | Canon PIXMA MP530 All-In-One InkJet...
I changed my catrige but its showing the error E5
I use refilled cartridges. Okay, the printer says ink low, but it does that all the time. I ignore it. However, yesterday it printed not a problem, today it gives me code 5. Does anyone have a real solution or should I throw the printer away?
Jun 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Hi their My MP530 printer reads CHECK CARTRIDGE U052, the manual does not help, can anyone help me please?
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
Nov 19, 2009 | Canon PIXMA MP530 All-In-One InkJet...
After 2 years trouble free service, error 'U052 The type of print head is incorrect' has appeard?
Jul 17, 2009 | Canon PIXMA MP610 InkJet Printer
Printing Error...
Hi!
The U052 error means that the 'chip' fitted to the Cartridge is not responding . They fit these chips to try to prevent refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and the chips are particularly sensitive to static / damage. Many people end up blowing the chips during the swap over
Please rate this solution.
Thanks
Rylee
Feb 10, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Cannon MP600 error message U052
Hello all, I have had an MP600 for a few years now, and after paying about £50-£60 a set of inks i decided to use compatible ones and i also spent £20.00 on a ink resetter from Sudhaus http://www.patronenhandel.de/shop/en/Redsetter/MP-Serie/MP-600/mit-Refill-Set
After about a year of owning the MP600 i got the dreaded U052 error, so i went back to genuine inks, however this did not clear the error. i then decided to telephone Canon and they advised me to clean the print head thoroughly. If you look at the print head there is a white plate with 2 screws either side, i rmoved that CAREFULLY and cleaned behind it, i reinstalled everything back to normal and 2 years later i am still running perfect with no issues what so ever...I'm not sure what resolved the issue but i now refill my genuine cartridges myself and reset the chip with the Sudhaus resetter. To refill your cartridge use the tube inside the genuine ink cartridge DO NOT refill from the top, you will see the 2 arrows on the GENUINE ink cartridge pierce between there and use a long syringe to refill.
Hope this helps people in the future.
Jan 15, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP530 U052 Error
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Feb 05, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
10,517 people viewed this question
Clive
Clive
old marine
old marine
Ekse
