Televison & Video Logo
Posted on Aug 25, 2008
In car dvd by acoustic solutions. bought from e-bay as reconditioned. player says loading then stop. press play and seq play comes on screen and no dvd is played.
  • 1 more comment
  • Anonymous Sep 03, 2008
    seq play but will not play
    first it says stop. if you press play it say seq play and will not play nay disks
  • Eduardo Garcia
    Eduardo Garcia Jun 17, 2016
    Wat does it mean
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 03, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
548
Points
What does this stand for it comes coming up when I push the DVD menus button ( SEQ Play)
Hi Beverly it sounds like the DVD player is asking if you'd like the discs in the changer to play the next one automatically, and there should be a shuffle alternative, or a play1 then stop choice as well.
1helpful
The dvd player doesn't play the dvd's
when i load the disc it spins for 5-7 seconds then quits and the poer light, play light and loading light flash continously. model p421
2helpful
2answers
GPX portable DVD model PD808B - wrong region message
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can now choose between regions on the screen. Select the desired region unlock and press 'enter'. This works well!
Benony Jonsson
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
3answers
Not able to play region 2 dvds
With remote control and player stopped,
press setup, vol+, vol-, vol+, vol-
Use arrow keys to select region 1-6 or 255 for all region.
Numbers appear on TV screen.
Press setup again to save and exit
Try this to make it multiregion. It should work.
3answers
I need a code for acoustic solutions dvd player to play a bubble console
I contacted bubble support to get code for acoustic solutions dvd to load bubble system into dvd player.
thanks for email.
gill gherman
Unlock regional codes
1 PRESS THE OPEN BUTTON ON THE REMOTE
2 PRESS SETUP
3 PRESS THE NEXT BUTTON
4 PRESS STOP
5 PRESS PAUSE
6 PRESS NEXT REPEATEDLY UNTIL THE NUMBER 2 APPERS ON THE RIGHT HAND SIDE OF YOUR SCREEN
7 PRESS RIGHT DIRECTION BUTTON TO CHANGE TO 255
5helpful
3answers
Portable DVD showing blue screen
i have the same dvd player the pink 1 i lent on a button and it went into black and white i have tried everything and can't seem to get it back into colour again, ive tried pressing all the buttons and nothing seems to work or come up with any black and white/ colour options :(
1helpful
Portable dvd player Film's stop and go back to loading screen
Not sure it's a solution, per se, but I discovered that my Matsui was acting as if I was opening and closing it, so I guessed that it was the lid. Once I put a paperweight on the "Press to Open" part of the lid, the DVD played through. I'm looking how to fix the lid but that's a workaround for now. Best of Luck - M
Coby dvd player
do you see the laser light come on when the disk spins if not it has probably lost power or failed, if so sometimes the laser head gets moved to close to the drive mechanism and the motor cant pull it out. i have found several of these that had this problem.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
