HP LaserJet 2840 Printer Logo
Posted on Jul 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP color laserjet 2840 for Mac -- Pages print but are totally blank. Appreciate if you can advice A.S.A.P
Anonymous
Level 2:
  • Expert 304 Answers
  • Posted on Jul 06, 2011
Anonymous
Expert
Level 2:
Answers
304
Questions
0
Helped
202345
Points
741
  • The sealing tape might still be in the
    print cartridges.
Solution "Verify that the sealing tape has been
completely removed from the print
cartridges."
  • The document might contain blank
    pages.
Solution "Check the document that you are
printing to see if content appears on all
of the pages."
  • The device might be malfunctioning.
Solution "To check the device, print a
Configuration page."
Orn Wilson
Level 2:
Scholar:
  • Expert 104 Answers
  • Posted on Oct 20, 2019
Orn Wilson
Expert
Level 2:
Scholar:
Answers
104
Questions
0
Helped
73158
Points
203
The solenoid that controls the carousel movement is sticking throwing off carousel home position. The laser scanner beams are actually hitting the black plastic carousel instead of the cartridge drums therefore getting blank pages with no error codes. This was an early color machine that didn't have the error code 59.xx (transfer belt movement errors) that is currently in the error code list for newer HP color printers. This solenoid is not that difficult to get to. Just remove the sticky substance (self explanatory once you get to it). When I clean these I used blue painter tape on the sticky areas when reassembling which works for me, but you can do whatever...just get the sticky off!!
2answers
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
3answers
2answers
Hp laserjet 2840 not printing
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-2840-prints-blank-pages-or-yellow-only/td-p/2326639#.Ur1kMH_lMgU
2answers
HP LaserJet 2840 all in one printer prints blank pages - no matter if a word or excel doc..printer goes through but page comes out blank.
Not to sound like a smart aleck...do you have enough toner in it? Can you print a test page? Sounds like a toner issue to me.
1helpful
2answers
HP Laserjet 2840 asked for drum replacment afther only 5300 pages but should make 20000. Prits where still perfect but now it refuses to print. Any solutions how to keep using the drum?
Check online for refill instructions and where to buy the chip to replace on the drum, most of the drums today have little chips to replace that tell the printer when they are used up, even when there's still life in them.
1helpful
2answers
Jam in print paper path HP 2840 printer
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
1helpful
2answers
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
2answers
HP 2840 All in one won't print color
printer is ok, check the connecting cable and drivers.
HP Color LaserJet 2550n printer - Paper feeding fine. No print!
Have you checked that you are sending the print job using the correct paper tray on the printer? Check the properties of the printer to ensure you are. Check also that the printer is OK by running a test print from the printer and not through the PC. If I remember it's hold the green button for around 7-10 seconds, whilst powering on.
k24674
Grand Canyon Tech
Grand Canyon Tech
