No - Your TV has tubes not lamps.
Why do you beleive you need to replace the tube. 99% of the time the problem with this model is just the fluid.
Projection
TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look white,dull, red/orange, etc. You may even see white halos around
images.
Here is a photo of a set that needs the fluid changed.
TV set after fluid change
Solution
What you will need to do is replace the coolant and clean the crt lens. You can get a repair kit from
www.TvRepairKits.com that includes replacement coolant, photos, step by step instructions, etc.
