Question about Hardware & Accessories
Timer Model #: 49550/TM151P I've lost the pins for this model. How can I get replacement pins? Your help is most appreciated. I'm willing to pay for them.
Open following link to identify timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#49528
This Woods timer does not have replacement trippers available.
Replace with Intermatic TN311C
Posted on Jul 05, 2011
  • Anonymous Jul 07, 2011
    You say help is most appreciated, and offer to pay, and then downvote the correct answer from somebody who got paid nothing. The trippers are simply not available unless the timer is Intermatic. That's a fact.
SOURCE:
Manual
Copy following links for Paragon 8000-9000 series sell sheets, general information, otherwise there is no operation manual for this product.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
http://waterheatertimer.org/images/8145-work-image.jpg
Add a comment and describe what part of timer is wound tight.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 28, 2013 | Paragon 8025-00 Enclosed Indoor 24 Hour...
My Eurosonic 7 day programmable timer doesn't activate. I've lost the instructions, are they available?
1) Eurosonic appears to analog timer:
http://waterheatertimer.org/How-to-set-timers.html
2) There is new series of digital timers from china, also sold as Eurosonic:
Copy following link for possible manual. Always reset digital timers before programming.
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
3) Add a comment March 2013 and describe timer in detail
Mar 10, 2013 | Hardware & Accessories
I have a noma 49550 and the timer let the turn on and the wheel spins as well but it doesnt shut off even with the pins and i dont know what the wheel at the top is for, is that the issue???? please help...
I don't have repair for defective timer.
The wheel at top is probably the issue. Move the wheel with your thumb and experiment with the timer.
As a general rule, the timer will not bite you.
Open following link for analog timer instructions:
My files show that 49550 is analog timer with trippers that install on timer dial.
Aug 19, 2011 | Hardware & Accessories
I want the wiring diagram for the clarion radio model number RT-142F. This is an early model and not a stereo model.
You've probably sorted it by now, but.....Cleaning out my shelves - I've just cleaned up one of these hoping to sell- If it's just the connections you need, - straightforward- there are two receptacles to the rear socket, the one which has two pins is the speaker and the one with the single pin is the power input, +12v. I'm almost certain that it will use a 4 ohm speaker. Don't ground any of the wires, just the cabinet. If you need a service manual, can't help.
Jul 17, 2011 | Clarion Car Audio & Video
I just bought this timer and do not understand how to find pins. III Woods Model 59204EV
Here's the 1-page "manual" fo ryour timer:
https://www.ccixpress.com/wcsstore/CCIxpress/images/catalog/catalogPDFs/Part%20No/59204.pdf
As an electrician, I rarely have to dal with these plug-in timers, since when they fail, consumers
will just discard them and buy another, but as a timer owner, I can try to describe the "pins" and
operation of your Woods 59204ev timer.
1. rotate clockwise the center dial to inform the timer what time it is now.
you'll want to rarte the dial until the time on the dial points to the ARROW.
The dial is marked in either a 12-hour or 24-hour format.
2. the "pins" are on the outer edge of the dial - tilt the pins OUTWARD during the time(s) on the
timer's dial that you want your timed devce (10 Amp max lighting, 15 Amp max resistive (heater))
to be on, and tilt these pins inward for the times/hours that you want the same device to be off."
Thes pins are advertized to be "Never-Lose" pins, since unlike many past model timers, the
on/off pins for your Woods 59204EV timer are not removable. Consumers would consistently
lose or break the small plastic removable pins of yesteryear, rendering a fully functional timer useless.
May 16, 2011 | Hardware & Accessories
On the Noma timer Mod 49550/tm151p how can you tell when the switch is on
1) Noma is old Intermatic brand name used by companies today to brand their timer.
2) Noma is usually associated with Woods timers.
3) Woods numbers also frequently start with 495 and with TM.
For example Woods has 49588 49556 and 78 84 29 28 62 57 33 53 65 44 68 32 77, but 49550 does not show
4) It is likely that you have a Woods brand timer.
5) Add a comment with in-focus photograph of timer for possible identification
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
6) Open following link to possibly identify timer, and then add a comment saying which timer is same-similar to yours.
Read troubleshoot section to see if your answer is there:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Apr 22, 2011 | Hardware & Accessories
Is there anyway I can get a replacement Pin for model #49529/TM 158DS? I'm missing one Pin. Any help would be greatly appreciated! Thanks
Woods 49529 is a segment timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#49529
Woods timers do not have replacement parts or pins since local retailers Walmart, Lowes, Ace, Target, CVS etc sell them inexpensively.
Buy similar timer on-line for $9.
http://www.amazon.com/59366-Appliance-3-Prong-Outlet-Repeats/dp/B001D8VIKE
If You have a different timer, add a comment with description of timer.
There are Intermatic and Tork timers that have replaceable pins.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 19, 2011 | Woods Hardware & Accessories
Intermatic Time All ,model TB111. lost plastic pin
I have the pieces for an Intermatic Time All, model TB111 because mine stopped working. I don't know how to get in touch with you.
Jul 20, 2009 | Intermatic Hardware & Accessories
Hardware & Accessories Logo
391 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
