Question about Kitchen Ranges
Panasonic microwave oven NN-5262SF. Totally dead after electrical storm. Plugged into live outlet. Even the light and fan dead. Believe a fuse in the oven but don't know where it is located. Can you help me find it?
  • pdylhoff Jul 11, 2011
    I took the microwave oven off the wall, checked out the back, and could not find any port to open where I could access a fuse. The only way to open it up would be to remove the entire sheet metal cover which surrounds the back panel. This appeared to be a huge task (as opposed to removing a port cover) and then I still had to locate a replacement fuse somewhere. I chose to replace the oven with a new one.
    The solution I was given appears to be a generic one.
    I was not pleased with the advice as it was not specific to my model.
    I don't want to accept this solution.
    Phil Dylhoff
    I took the microwave oven off the wall, checked out the back, and could not find any port to open where I could access a fuse. The only way to open it up would be to remove the entire sheet metal cover which surrounds the back panel. This appeared to be a huge task (as opposed to removing a port cover) and then I still had to locate a new fuse. I chose to purchase a new oven instead.
    Phil Dylhoff
    Genius:
  • 1,157 Answers
Hi pdylhoff,
Try to replace the fuse using the instructions below. Replacing the fuse will determine if it's the cause of the problem.
1. Unplug your microwave. Remove the screws from the back panel. Take off the back panel.
2. Find the fuse. It should be near where the electrical cord comes into the microwave. The fuse is a small white bar with metal caps on either end.
3. Carefully remove the fuse. Avoid touching the transformer or other parts inside the microwave.
4. Take the old fuse into the store to find the exact match. You may also use the owners manual to find out what kind of fuse is used.
5. Replacing the fuse. Please put the cover back on and see if your microwave works. If it does, replace the screws. If it does not, try a different fuse. If the microwave still does not turn on, you may have to have it replaced by an authorized repairman.
Reminder: Please do not touch the transformer on the inside of the microwave. It can discharge enough electricity to cause harm or even death.
Hope it helps.
Thank you for using FixYa.
Posted on Jul 05, 2011
SOURCE:
The oven is totally dead. No light, fan etc. Replaced fuse internally, found no current at the fuse. Outlet has 120 v. Oven was run empty prior to going dead! Any thoughts?
check power between power cord connection and inernal fuse,start at cord connection and work way to fuse conn.eliminating possibe problem area
Oct 11, 2010 | Maytag MMV5000 Microwave Oven
NN-T964SF 1250 Watts Microwave Oven: my microwave went dead and wouldn't turn on at all...
Sounds like a blown fuse. Carefully remove the cover, and the fuse in directly behind the power cord on the top. Radioshack sells 15A ceramic replacements.
May 17, 2010 | Panasonic NN-T964SF Microwave Oven
My micro oven NN-C2000P No lcd light display even the 240 v suppy is going in the Power supply panel. the door is totally close.
IS GREEN LIGHT IS ON BEHIND LCD ? ANY LCD NEEDS BACKLIGHT TO DISPLAY. JUST LOOK OUT FOR FUSED BACKLIGHT. LET THE DOOR OPEN OR CLOSE THE DISPLAY SHOULD BE ON.
Apr 01, 2010 | Panasonic NN-T551 Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Completely dead; has good power source and fuse ok
Where the door closes there is a a switch you have to take off the cover (plug out device) one of these switchs are probably burnt out
Sep 23, 2009 | Panasonic NN-S541 Microwave Oven
Microwave oven
Check the wall AC outlet by using a meter or another electrical appliance such as a table lamp. If no power there replace the fuse or reset the circuit breaker.
Does your microwave light up when you open the door?
If not, it could be a bad power cord, on/off switch AC cord or fuse.
Check these first.
If you cannot solve the problem, you'll probably need service.
Hope this helped.
Mar 25, 2008 | Panasonic NN-P794SF Microwave Oven
Dead microwave
check mains fuse and check control circuit and magnetron. and diodes capacitor  high voltage related circuit. small part also gone microwaveoven doesnot works, first check oven and conform which part was spoiled, after that this is worth or not old ovens good compaare to new ones...
Oct 25, 2007 | Panasonic NN-T888S Convection/Microwave...
Kitchen Ranges Logo
162 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
