Broderbund The Print Shop 21 Deluxe Full Version for PC Logo
Posted on Jul 05, 2011
Can not install Print Shop Pro Publisher Version 21 will not load on Windows 7
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jul 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
988
Points
24
You can try setting it to run in compatability mode.
Right click on the program Icon
Click properties
Then click compatability tab
Check mark Run this program in compatability for
Select windows xp in the drop down list.
Click apply then OK
Try running the program
If this does not work try
Right clicking on the icon of the program and selecting run as administrator.
This program version is not supported by Windows 7 so if this does not work the you will need to upgrade to Version .23 instead of .21
My project does not print with the correct color - even using the "best" setting. I have a gold background and it's printing with a blue/gray background. The photos are in color, but the...
Double check that none of your printer's jets is blocked (test page!) and convince Print Shop and your printer's settings that your process colors are the ones in the printer, e.g. RGB or CMYK versus CKMY, 7-color, etc.
1helpful
Is it possible to install Print shop version 11 on windows 7?
according to their site its not compatible to Win 7 means it can install but not all most all the functions are available but they are up to release a new version with compatible to win 7
I have a Print ship Pro Publisher Deluxe which is not working with my Windows Vista in converting the file to pdf. The Broderbund pdf printer will not set up. It keeps telling me there's an error in...
I would try installing another pdf printer, like the free PDFCreator. That way you could just choose a different printer from your Broderbund software, and print the same file to PDF.
Give it a shot :)
Good Luck
Print shop 20 pro publisher not working properly with windows 7 upgrade. Is there a download to make it compatible with windows 7.
Here is a link that will check compatibility, http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?type=Software&s=print%20shop%20pro%20publisher%2023
You may want to uninstall the program and then install in compatibility mode, the link below will guide you through this,
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the above does not work, you may want to contact the software developers to see if any updates can be used to fix the problem.
Installing Print Shop 21 in Windows 7
Print Shop version 21 Deluxe is not compatible with Windows 7. You have to use a newer version 23 which is compatible. This is due to software compatibility with Windows 7.
You can check forcompatibilites issues @ Windows 7 "software & hardware" compatibility center
2helpful
Unable to install Print Shop verison 11 on my Window 7, why?
Print Shop Pro Publisher version 11 was built for Platform OS: Windows 98 / Me / 95. It is an old software which is not for Windows 7(x86 or x64) OS. This is due to software compatibility issues with Windows 7 ie an old software running on a newer OS Platform.
You have to get a newer version which is compatible with Win 7.
Hope it helps.
1helpful
Will the Print Shop 21 Pro Publisher Deluxe run on Vista?
Hello Friend,
This version is not supported by Vista, you have to upgrade it to "The Print Shop® Pro Publisher™ Deluxe 22 " version.
Visit the link below for more details:
http://www.lazydesis.com/software/72024-broderbund-print-shop-pro-publisher-deluxe-vista-ready.html
Thanks,
Shiva
1helpful
2answers
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
