SOURCE: Sony HDR-HC3 camera won't connect in HD mode in iMovie HD or FCP HD
What software are you using to capture the HD footage? Are you using the supplied software, or another package. It is likely that you have a software incompatibility. i.e. windows will recognise DV natively, but HDV requires specific codecs and software installed on your PC.
SOURCE: HD Video Capture Problem
Which software package are you using? My brother was able to solve the HD capture problem by using Adobe After Effects.
SOURCE: download footage from my sony HDR-cx100 to mac
You can view your footage with VLC. The best way to import your files is with Final Cut Pro's Log and Transfer.
SOURCE: sony video camera hdr-cx110 ...
How I fixed the E:61:00 on my Sony DSC-P71 digital camera. Symptoms : · After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen. · Camera would extend the lens but not be able to focus on anything past 8 inches or so. · Zoom in and zoom out would not work. · Playback mode and the Setup mode was not affected. A Picture of the E:61:00 Error Message Solution : · Turn the camera off · Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface. OR reference the video files below for an alternate method. · Turn the camera on · Let the lens extend into the hard surface, don't let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time). · Lift the camera away from the hard surface and notice that the error message is gone.
This may sound crazy and this has not happened since I did this but here is what I did to get rid of that error message. I have not had that problem since but here was my steps:
