Question about Goldstar DH504EL Dehumidifier
Goldstar dehumidifier I have a goldstar dehumidifier and I ordered a hose connector so I do not have to empty the water bucket. I hooked up the connector which doesn't seem to go anywhere and of course it doesn't drain the bucket
  • Anonymous Mar 18, 2014
    I need to know , when i use the dhumidifiers , there is hot air going out in the back, ai cool air going out from the front. Also do not seem to drain water ??
  • 1,543 Answers
The hose connector does not drain the bucket, it drains the condensate before it enters the bucket. Tube passes through back of dehumidifier by the cord wrap area. (you may have to remove a small cover)
Posted on Sep 15, 2008
SOURCE:
WE have a gold star dehumidifier - 4838 AD 1002-6. I was emptying out the water this morning, and dropped the bucket on the cement. I think I did something to the auto shut off. Everyting looks ok,...
Sounds like you're going to need a new bucket & float, if you want to continue to use the dehumidifier in any thing other than continual hose draining mode.Here's a link to where you can find a replacement bucket w/ the float valve included. http://www.appliancefactoryparts.com/dehumidifiers/partinfo.php?partsid=276540
I hope this helps and thanks for choosing FixYa.
Jul 30, 2011 | Goldstar Dehumidifiers
Where can I get hose ,hose attachments for my Goldstar dehumidifier? Can not locate my manual or attachments.
Fortunately, it doesn't require a special hose, as a standard Garden Hose Connection is on the left side of the water collection bucket. You may have to carefully drill a 1/4 " hole in the center of the connection, once you unscrew the drain cap. The hose should be no longer than 5' , as the drainage relies entirely on gravity to drain.
When attaching the the hose, be sure that the female hose connection has a washer in it or it will leak. Hand tighten the hose connection firmly, being careful not to crack the plastic hose connection on the tank. Also, be sure that the float valve in the tank is in the DOWN. position or the unit will not run.
Hope this helped you. Please let me know.
Jul 08, 2011 | Goldstar DH304 Dehumidifier
I turn my dehumidifier on and let it run for hours, but when I go to empty the bucket, there is no water in it.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Mar 01, 2011 | LG DH504E GoldStar Dehumidifier
Bucket is empty, fan comes on to start up runs for about 2 seconds and shuts system right back off
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 26, 2010 | Goldstar DH504EL Dehumidifier
How do you hook it up to a floor drain?
With most portable dehumidifiers use a bucket to catch the condensate. Then the bucket is full the dehumidifier stops, then you need to empty it and replace the bucket to get the dehumidifier to start working again.
To make this unit run continually, the bucket can be modified so a garden hose can be attached and the hose can be feed into a floor drain. To do this look at the bottom of the bucket, there should be a hose connector where you can attach a standard garden hose. You will need to drill out the center of the hose connector with a 1/4" drill bit. Then you can attach the hose to the bucket and the other end into the floor drain.
Jul 01, 2010 | Whirlpool AD25BBK Dehumidifier
GoldStar DH504EL Dehumidifier
Your dehumidifier should have come with a tube which would allow you to do this very easily. I beleive the part number is 5214A20027B.
Sep 15, 2008 | Goldstar DH504EL Dehumidifier
hey i just got paid by some guy to haul away a broken fan(currently fixing) DH504ELY5 dehumidifier on my model with bucket removed front facing you reach to the far right the orfice there drains to the bucket id only assume just get the proper od hose(even clear) from a hardware store attach it and it should be fine- take back panel off(plastic 6 screws and youll have to gently pry the "clips" out of the steel back-dont worry if one breaks the screws will still keep the back on on reassembly) there is a hole with a foam kinda adhesive tape over it it is perforated for the purpose of an external hose feed it through there and out of the hole thats in the middle of where the power cord winds up for storage-all will be a straight shot on reassembly no twists or turns try that should do the trick and you can keep the bucket on there:)
Aug 02, 2008 | Goldstar DH504EL Dehumidifier
Goldstar DH504EL Dehumidifier Logo
548 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Paul
Paul
Michael Youngman
Michael Youngman
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
