Computers & Internet Logo
Posted on Jul 04, 2011
I cannot connect "wireless" with my TENDA model
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jul 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
1463
Points
22
TENDA model W268R default IP 192.168.0.1 username: admin password: admin
Reset the Router and reconfigure again....
2answers
Why doesn't my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
How can i set a new password intenda wireless router?
You will need an lan or wlan connection to your router, the service/ip address, 1st, open to your web browser, 2nd, type in your service/ ip address into the link, 3rd, login to your router's settings, and find the wireless setting. if you do not understand these steps, please consult you manual for "login to router" settings, or find the web site, and find user assistance.
Tenda-556038 wireless password
je cherche code pin Tenda-556038 perdu
remerciements
Unable to configure the repeater mode.
Tenda router is a very good network service provider, Tenda router has more than a million users across the country. It has provided high-speed internet, multiple sharing options, easy for connectivity with other devices and etc. But some time router users faced problem with this router service and not be solved to the issue, we are providing a Customer Service which is Tenda Router Customer Service Number. The customer contact by dialing a toll-free number +1-833-284-2444 and get immediate solutions.
When Tenda Router Not Showing Internet Light:-
Follow the given instruction and make problem free with your Tenda Router.
l First of switch off your modem & router
l Give it a rest and wait for a few minutes
l Switch On the modem & router
l A blinking light for internet connection will appear
l It will get stable in few seconds
l If you see the stable green light that means the issue is resolved.
When users get trouble for configuration contact our customer service number and get the solution for configuration, Tenda router service is wired and wireless service provider which solves the problem by taking just a minute and give the solutions. Customers also can get connected with Tenda Customer Service in case you find any issue.
Tenda Has genuine interface for his customer and providing guaranteed services. Some time customer wants to another technical service and they are can't take solution by a service number so we have an all technical solution platform which is providing any kind of services so visit our service number website and get solutions.
https://servicenumber.org/tenda-customer-service.html
3answers
How to remove password from tenda wireless
Push and hold th reset button for 30 seconds or so, the will reset to factory settings. This may help: http://www.tomshardware.com/forum/32272-43-tenda-w311r-installation
Tenda router input eror
It's not the username and password from your ISP. If you try to access your router and you have not changed anything, use the following values:
username = admin
password = admin
Once in the router interface, you will have to configure the router for your DSL-modem (I guess it's DSL since Windstream does not produce cable modems.)
Here fill in the username and password your ISP provided you with.
Let me know if you have any questions.
Wifi connection problems
Wi-Fi connection can create problems for various reasons like incorrect browser settings, errors in cable connection, misplaced passwords or a modem requiring reset.
what problems you are getting???
2helpful
Trying to set new password for tenda wireless router
you need to access the router's GUI page to change the security key of the routers/
remember, once you change the security key, it should be changed in all the devices you got connected wireless.
you can access the GUI page by typing either 192.168.0.1 or 192.168.1.1 (most of the routers have this default setting) in address bar of internet explorer.
you can find the exact numbers by going to start>run>type "cmd">type "ipconfig">enter
you will see the default gateway number which is the one you need to type in a address bar of the internet explorer. (these steps work only if you get the computer connected with the Ethernet cable first to the router)
once you access the gui page, you have an option to change the wireless key under wireless section>security.
need to mention that when you access the GUI page, you will be welcomed by a username and password log in option. the default username and password again is admin in most cases. if it doesn't work ,check with the manual of the router you got.
if you still need more clarifications or steps on this, please reply to the post.
My wireless adapter cannot see any wireless networks in range
you have a problem with the range or apear one indicator network work of ? if is the first maybe the ip adrees is corrupt in you mac conections or if not apear any your airport mac adaptor is work out change it vote plase
1helpful
2answers
What is my wifi password.. please help me.. i cant remember it .thankyou :)
Please access router's configuration page by typing 192.168.1.1. on a browser's address bar and hit enter. You are supposed to get a login page. Please use default login credential using the info below.
Username: admin
Password: admin
If this username and password is rejected you may reset the router to its factory default settings by pressing the reset pin hole on the back of this device. You will need a paperclip to do it. Hold it down for 10 secs while the router is on. Leave it for about a minute and try accessing the configuration page and try the default username and password again.
As soon as you are logged on please look for a wireless settings tab. Look for the wireless key if it's all dots or asterisk you may go ahead and change it. Take note if there are some other wireless device connected to this router all of them will be disconnected but what you just have to do is to reconnect then using the new wireless key.
Thank you!
Grand Canyon Tech
Grand Canyon Tech
