What is the model number for the samsung dryer? Usually when this happens there are small thermistors that act as safety devices in the dryer that will prevent the unit from running. For example there is a hi and low limit thermistor that if either will faulty the unit would not run at all the lights would come on but the unit would not run to prevent the unit from getting to hot. Message me back your model number and I will find your schematic showing the thermistors in your unit. You would have to check these thermistors with a multimeter and perform continutity tests on them to assure that they are functioning properly. I await your reply Thanks Rick
thermostat location at 1-4 on this diagram click this link http://www.searspartsdirect.com/partsdir...
you also have a radiant sensor as well at 1-2 you also have thermistor locations on this schematic as well click this link http://www.searspartsdirect.com/partsdir... the thermistor is at 2-3 and another thermostat at 2-4 you also have a micro switch that if the belt were to break on the unit the unit would stop spining and trip the micro switch causeing the unit also not to run which is located at 4-3 check these areas and message me back with your finds Thanks Rick
Hello Dr. hayden I am unable to see your replys on the beta version for some reason so if you need further assistance message me on here or at [email protected]. Thanks again Rick
That is because you went on the beta site to give your response which i never received stay on this site do not go on the beta I am not able to view anything you write on the beta site and actually ignore the email thing think I caught a scolding for giving that out but trying to contact you on how you made out with tests. I await your reply Thanks Rick
Awaiting your reply Thanks Rick
dryer dv350ag has power but will not start
model # is DV219AGW/XAA
DV219AGW/XAA
This is a joke!!! Pleasae refund my money for the service, The technician wants me to respond with model number which was all ready supplied in the initial information - Also there are no links to connect with the tech. asked for help and received no responce!!!
DV350AG
I have same problem but my model is dv330agw. I purchased a thermistor and two thermostats but which is best way to install them.?
I HAVE THE SAME PROBLEM WITH MY SAMSUNG DV350AGP/XAA. I AM TRYING TO FIND HELP ON THIS MATTER TO SEE WHAT THE PROBLEM IS
