HP W1707 LCD Monitor circa 2008 old. 10 years old NOW.
No PC stated or any OS at all. windows what?
connected to what? it must be connected to a working PC
or the monitor is useless as 3rd shoe.
i can only be 2 things, PC or screen bad.
the monitor has no software ever.
only the PC side does for the PCs video chip GPU driver.
but the PC always has one, even if, poor quality resolution.
Toss magic coin land on bad w1707
The screen, can fail for many reasons lets say it fails on a good PC. known good.
these old monitors have CCFL lamps that love to fail inside.
It has no LED back lamps , before 2010. it haS CCFL lamps.
The monitor all by its self, pc disconnected.
you power it on and it shows logo, HP or Compaq
then for seconds turned on the menu may work.'
if you see nothing the CCLF are dead.
The menu button works only with good running PC. but
might work for 1 second.
some do others dont but only for seconds does the OSD work
lacking a good PC connected.
the OSD is the menu from the monitor brain inside
the button is called select or menu.
PC turned off and Monitor now turned on the screen shows.
if the PC is dead the Monitors brain then shows.
NO SIGNAL , or NO sync.
or if PC is set up wrong the monitors shows, OUT OF RANGE.
CCFL love to fail.
the lamps turn yellow, blink or go DEAD.
as can the HV inverter seen here.
http://www.pcdied.com/monitors.html#Inverters-monitors
PAR:
i one uses the monitor 10 hours a day
on the 5th year, the CCFL goes dead. that is there normal life span.
SOURCE: display problem
When the screen goes dark shine a flashlight in the lower right hand corner where the Start button typically is located. If you can see faint images then you have a backlight problem. If you don't see anything then try connecting a spare monitor in its place. If that works then you have some other type of problem involving your LCD monitor. In both cases unless you have the experience and tools to safely work on fairly delicate electronics this is not a repair job for the typical consumer.
SOURCE: problem on hp monitor
I know you said there were others that had the
same problem with the Main Menu coming up and I thought I would tell you
what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and
slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back
cover.
At the bottom of the monitor case, there is a small circuit board the
holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second
switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence
while holding the switch with a pair of needle nose pliers. I had to
rotate this process from one prong to the other while all the time
applying slight pulling pressure on the switch pulling it away from the
circuit board.
8. Once the switch was removed, I put the cover back on and tightened
up the five screws.
9. Then I slid the base back in the slot it came from and tightened the
four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so
very happy.
SOURCE: menu(user mode )display is coming again and again?
While your PC is turned on, disconnect the monitor, and unplug, then plug it back in, and reconnect it back to PC..
SOURCE: HP Pavilion laptop screen has gone black/blank
No it suggests you have a bad screen and it needs replaced
SOURCE: blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Testimonial: "I am very happy that this guru was able to concisely evaluate the problem from the information provided. "
Double-click the "System" icon. Choose the "Device Manager" tab. Press the "+" next to "Display Adapters" to view installed display adapters. Highlight the adapter listed and click "Remove" then "OK." Close all open windows and restart the computer.
Press the "F1" key at the blue HP screen. Enter set-up and press "F5" and "Enter" to reset all data. Press "F10" to save and exit.
Right-click the "My Computer" icon on the desktop. Select "Properties" from the menu. Click the "Hardware" tab, then the "Device Manager" button. Expand "Display Adapters" and right-click the graphics card. Select "Update Driver" from the menu.
Choose "No," and hit "Next," then select "Install From a List." Select the option to show all hardware. Choose "Standard Display Types." Select "Standard Display Adapter (VGA)" and hit "Next." Don't restart the computer.
Click the Windows "Start" button. Go to "Settings" and open "Control Panel." Click "Add/Remove Programs." Remove any i810 and i815 chipset programs. Restart the computer. After it starts up, go into the "Display Adapters" section in "Device Manager."
Open the "Standard Display Adapter (VGA)." In the properties window, un-check the box "Exists in All Hardware Profiles." Click "OK" and shut down the computer. Open the computer case. Install the new video card according to the manufacturer's directions
hope this helps
