Sony XM-SD22X Car Audio Amplifier Logo
Posted on Aug 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The amp does not say wat size it is
What size is this amp
Salrak Sangma
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 09, 2018
Salrak Sangma
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
102
Points
Can i used direct with Mobile mp3 without car mp3 with Sony 250w amp
Anonymous
Level 3:
  • Master 631 Answers
  • Posted on Aug 25, 2008
Anonymous
Master
Level 3:
Answers
631
Questions
Helped
237489
Points
1200
At 14.4v DC input...
200w RMS x 2 into 4 ohms
250w RMS x 2 into 2 ohms
Let me know if you have any other questions.
Wat size fuse do i use for the horn
Depends on the vehicle and the size of fuse. But you can use from 20 amp to a 40 amp
I have a volfenhag zx-8290 amp but i need to know wat size fuses it need
In all the pictures I can find, the fuses are clear, which means they are 25 amp fuses.
Jul 03, 2011 • GPS
1helpful
So wat is the tipe and the sizes of the jets that
There are probably 15 different main jets, 15 different needle jets, and 15 different pilot jets available for your bike. Go to www.babbittsonline.com/parts/viewbybrand/parts.aspx Input info on your bike then go to "carburetors" in the drop down list. Please rate my answer.
Hay i just brought da sub on its own and dont no wat a good size amp and power needed to make dat bumpn bumpn feel...and how to connect it all up plezzzz.... fnx DJ KINGXL out
buy a bridged amp with half the power of your sub (ie 1200 watt sub use a 600 watt amp) this will stop distortion at high volume get in touch when you have the amp and i'll go through how to wire it .
15helpful
3answers
Hi,wat is d size of samsung star wallpaper? wat size shld i download?
Model S5230 / 5233 - 240 X 400 pixels
Model S5603 - 240 X 320 pixels
Jul 03, 2009 • Cell Phones
What size fuse do i need with my 1200 watt 2 channel amp
hey 25 watt thats wat i have got and mine is a 1100 watt..
Wat do i need 2 install a sound system
You can go to your local car audio store, Walmart, Circuit City and buy a Wiring Kit they go by the size of your amps ( Watts ) you can get them fairly cheap and it comes with all the wires, and fuses needed.
I hope this helps answer your question. This is the best way really to get the right cables (makes the system sound better with proper wiring) The power cable has the fuse built in as well. Feel free to leave positive feedback if this helps.
Load calculation and size of wires
A lot of your questions also have distance that need to be factored in. Copper is way better than aluminum. but in large wires it may be too expensive, also some suppliers only carry aluminum in the largest sizes. If you are doing a lot of electrical, then you need to learn "ohms law." Also most appliances have the amp load printed on them on the I.D. label.
Dont no wat size fuse for lead
depends what wireing kit you are useing.if you are useing say a 300watt kit then the fuse in the main power lead is normally a 25amp fuse,and this should be installed a maximum of 12 to 18 inches from the batery. hope this helps.
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
