SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
A
Anonymous Posted on Jul 04, 2011
How to get the pc games to the removable disc(J) sandisk.Can not Move them to Flashdrive disc.
Anonymous
Level 2:
Novelist:
  • Expert 120 Answers
  • Posted on Jul 04, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
120
Questions
Helped
40866
Points
416
It is not completely clear if you mean large PC games or if you mean small PC games.
By small PC games I mean games similar to the games that come with Windows and that appear in the 'All Programs -> Games' folder. Such as 'Free Cell', 'Hearts' or 'Solitaire'.
By large games I mean games like 'World of Warcraft' or 'Mortal Combat'.
Also, do you want to install the games on your Flashdrive or store them there?
If you want to store a large game on your flash drive. Place the CD/DVD with the game on it in your CD/DVD drive and insert your Flashdrive in a USB port.
Open 'WIndows Explorer' or 'My Computer'. Locate the CD/DVD drive that you inserted the game disk in (most likely your D: drive).
In the 'Edit' menu select 'Select All' and then in the 'Edit' menu select 'Copy'.
Then locate the Flashdrive in 'WIndows Explorer' or 'My Computer'. And in the 'Edit' menu select 'Paste'.
While this will copy the files from your game's CD/DVD disk to your Flashdrive you may or may not be able to install the game from your Flashdrive.
You can use this same procedure to copy small games to your Flashdrive from your Hard Drive.
You will need to know where on your hard drive they are located. And they may or may not run from your Flashdrive.
Also you may be able to install and run games from your Flashdrive, When you run the Setup program from you game disk you will usually be given the option to select a alternative location to install the game.
Select your Flashdrive at that point and it may install correctly to your Flashdrive. If it does you should be careful to always use the same USB port or the game won't run.
Hope that helps.
JessicaChane2345
Level 3:
Master:
  • Master 415 Answers
  • Posted on Mar 28, 2019
JessicaChane2345
Master
Level 3:
Master:
Answers
415
Questions
6
Helped
225720
Points
1529
Hi, maybe you need CD Keys that may help you. Thanks and have a nice day!
3helpful
5answers
HRDP Password
HRDP password reset instructions Compatible Flash drives: SanDisk Cruzer Talent Flash Corsair Voyager Lexar Traveler Kingston Formatted to FAT32 (flashdrive) Plug in flashdrive to pc.. Select my computer. Right Click on flash drive from my computer select format. select FAT32 Copy and paste file to URL www.fusiondvrsupport.com/files/embedded/HRDP_dvr_install_2.5.7.50-3.0.0.60.zip DL File to desk top. Unzip file and copy and paste files only to the flashdrive. Do not move folder only files. Shut down HRDP. Plug in flashdrive. Power up HRDP. Update will perform which will default password.
1helpful
How do I put pictures from my home computer onto the SanDisk?
Once you plug the sandisk into your computer, a window should pop up asking you if you want to view the files on the disk, if it does, click on it. If not, just go to Start Menu -> My Computer -> (The Flash Drive). Move this window to the side so you can see the desktop aswell as the flashdrive folder. (You have have to 'demaximize' (Restore Down) the window so that you can see the desktop aswell. Then go to the start menu again and go to "My Pictures" or wherever your pictures are located. then, you can click and drag the pictures from the "My Pictures" folder into the FlashDrive's folder. Once all the images are copied into the flashdrive folder, you can unplug the flash drive and the images will be on it.
Hope this helped, Nathan Taylor
My sandisk cruzer 4 GB pendrive ws working fine but now whenever i try to format\copy\cut it shows location 0 with used space 0 free space 0 what should i do
Your flashdrive usually shows 2 drives when inserted to your computer, one is the U3 drive and the other one is the removable disk drives. U3 drive is your separate partition for the U3 system and in order for you to store, copy, format your flashdrive, you should be selecting the removable disk drive, not the U3 drive. U3 is a read only memory drive that is responsible for your U3 to work (just like portable applications). Hope this helps.
Sandisk flashdrive would work on vista but not on
some of the drivers and required files are not available in Win7 and Vista...so some progrms may not respond...this is a flaw in the recent OS from MS as the OS provided are stipped down versions not full versions.
move back to Visa if u can
Installing cd/dvd games on acer aspire one a110
Get an external CD/DVD drive (USB) and run the game from that. (It's probable that you are hitting a copyright lock that needs the original disc.)
(if you want a DVD burner, you'll pay extra. Generally, the CD-RW/DVD-ROM drives are fairly cheap now <$50.)
Scandisk/flashdrive
"Scandisk"? Do you mean "Sandisk"? If you do, there is no difference between a sandisk and a flashdrive. Sandisk is one of many companies that manufactures flash drives.
2answers
Sandisk cruzer micro flashdrive - not working on vista
you'll need to go to the sandisk site, and get a vista driver set..
SanDisk Malfunction
unfortunately the files cannot be recovered immediately, macs a are compatible with PC flash drives but not the other way around. you need to format the disk. go to start>my computer> then right click on the flash drive and then left click on format, then click ok. when it is done bring the flash drive back to the mac and put the files back on. now try putting the flash drive into the pc again
2answers
Sandisk Cruzer locks up my computer when i plug it in.
maybe the flashdrive is infrected witha virus or something
try to format it
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
