Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
Posted on Jul 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Power Wheels camo brute force that we got for my son 2 Christmases ago, today I noticed it is not working at all, nothing happens when the pedal is depressed on either of the 3 modes. The battery is fully charged, even charged a second battery just to be sure. Please advise.
Anonymous
Level 3:
Brigadier General:
  • Master 3,301 Answers
  • Posted on Jul 04, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3301
Questions
0
Helped
1013933
Points
10058
Check for a shorted switch under the pedal , its just an on and off momentary switch, so just run a jumper wire between the 2 contacts, and if it runs, replace the switch , if it doesn't, use a meter to make sure the switch is actually getting power to it
1helpful
Kawasaki Brute Force™ 650 4x4i. It will start and idle fine, but when you give it gas it begins to miss and backfire
Question edited for full year make model.
Question moved from Cars and Trucks category.
You are not alone with this issue. Check out the videos and written articles.
https://www.google.com/search?q=2007+kawasaki+brute+force+650+misfire
1helpful
I have a 20015 brute force 300 and the rear wheels lock up after 20 feet like you slammed on the brakes when brakes have not been applied i was wondering what would cause this
heres service manual check brake spring or a shoe/pad problem but look up the trouble shooting section for assistance ------- https://quads.ddns.net/service-manuals/kawasaki/2005%20Kawasaki%20KVF%20750%20Brute%20Force%20Service%20Manual.pdf
2helpful
2answers
Hit the start button and nothing happens 2008 750 brute force
Check your starter solenoid. You can trace it by following the power wire from the battery to the small solenoid block that contains a 30 amp fuse. You can bridge the posts on the solenoid by using needle nose pliers or whatever else you may have. If it starts up or you hear the starter run, you have a bad starter solenoid.
Brute force 2009 750 runs but will back fire an stop
How long since the oil has been changed? Is the oil level OK? It sounds like you have a sticky valve that hangs open once in a while.
3answers
When I plug in the wheel to my PS3 and put the adapter into the wall the wheel calibrates and works but when I plug the wheel into my PS2 nothing happens! I've even left it plugged into my PS2 for an hour...
frkzila2, did you ever find a solution to this? I bought this for my son a few years ago and he NEVER used it... now he's in his teens and tried using it but it doesn't work... left light blinks, right light is solid, wheel moved slightly when initially plugged in, but no power what-so-ever to the pedals??? did you ever fix yours?
5helpful
2answers
Need to replace wheels on sons power wheels kawasaki brute force fisher price car. i have the wheels but have no idea how to remove old ones and put new ones on. thanks
I just replaced the wheels on the red Fisher Price Kawasaki Brute Force. First use a screw driver to pop off the grey middle nut cover. Then pull of the locking nut with black cap that is under the grey cover you just removed.
Once that is removed the wheel comes right off. There are 4 phillips screws holding the hubs together. Unscrew those and the hubs separate into to pieces (one on each side of the wheel).
Simply place the hubs into the replacement wheels and screw back together. Slide the new wheel on (make sure the washer is still on the rear side of axel).
My replacement wheels actually came with the black replacement locking nuts taped to them. Hammer the replacement locking back on the alex, pop the grey hub cover back on and you are done.
If you are missing the locking nuts, take one of the originals you removed with you to the hardware store and you should have no problem getting them. - MTRAGE
Mobile LG KG225 SL
generally the PUK code is mentioned in the instruction manual that comes along with the phone. try using 4 digit combinations(0 to 9) which will unlock.
Top Fisher Price Toys Experts
ADMIN Andrew
ADMIN Andrew
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
