Is the volume of your speaker is in its maximum volume cause sometimes when the speaker is maximize an echo in the sound appears, but if ever the volume of your speaker is not maximized and still there's an echo in its sound try this, go to the right bottom side of your desktop and find the orange speaker icon then double click it once you are in the realtek audio manager select sound effects then once your'e in there, in the environment choose none so that the echo of your speaker will disappear.
f you want to run Windows 7 on your PC, here's what it takes:
1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
16 GB available hard disk space (32-bit) or 20 GB (64-bit)
DirectX 9 graphics device with WDDM 1.0 or higher driver
So if your Acer TM4150 meets this minimum requirements, then you can install the windows 7 OS
