Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
Posted on Jul 04, 2011
Fashing code -1 and 38. - Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
A
Anonymous
2answers
tip
Get hot water from your Rheem tankless during a code 76 error
This doesn't always work, but on the Rheem tankless Gas/Propane water heater, if you're experiencing a code 76 error; disconnect the remote control unit (either from the water heater or the remote) by lifting the wires for the remote connection. Typically you'll get a C1-C8 error code, followed by a code 76; if you're getting a straight code 76 and nothing else, this procedure probably won't work.
Code 76 is a total power supply failure on the printed circuit board (PCB) assembly, which is the communication/power supply for the remote control unit. But, if you're getting a supplemental code (C1-C8) this procedure will most likely supply you with hot water until the replacement PCB arrives.
I am getting a error code on my tankless water heater from Rheem the code is C2
Do any other digits appear when you look at the LCD panel? Most Rheem Tankless water heaters will have a two-digit number in addition to the C2 code. Some of the error codes may be in your water heater manual. http://www.tanklesshotwaterguide.ca/about/rheem-error-codes-tankless-systems/ has some of these listed.
For example: C2 11 indicates a failure to light the gas burner (for gas/propane) units. This could be do to a shut-off valve that wasn't completely open. There could also be air in the gas line or insufficient pressure. There might also be a problem with the ignition/wiring.
A C2 00 code indicates that the burner was on for more than 60 minutes. For this code, turn off all open hot water faucets, including a dishwasher or clothes washer. Turn off the water heater. Turn off or remove recirculation pumps. Wait an hour for the unit to cool and reset the error code. Try the unit again.
Please add a comment with the full error code and the model number of the water heater for additional information.
I hope this helps.
I have a Noritz tankless water heater (model n-132m). I am getting an error code of 71. What does that mean?
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
What does code 36 mean
Error code 36 does not show in Rheem tankless manuals.
Copy following link for general troubleshoot and error codes, and Rheem contact information:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
No hot water error codes 76, C4,C7
Before calling service tech, open following links for Rheem troubleshoot resources including rheem chat, error codes, possible maintenance and service manual.
Error codes are considered start-point for troubleshooting.
Multiple error codes can mean PC board failure.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/pdf/Error-code-13.pdf
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
3helpful
Code f28 what isit?
According to the user's guide, the fault code means that the boiler failed to start after 5 attempts. Here is the manual where I got the information. I would confirm the codes with your particular model. I am presuming that the codes would be standard for all their models. Source(s): http://www.vaillant.co.uk/stepone2/data/…
2helpful
2answers
PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
